Results 1 to 1 of 1
Thread: EDA Data Logging
    Junior Member KDubya's Avatar
    Jun 2011
    Default EDA Data Logging
    I am having some trouble getting my V2 set up to do EDA logging. When I select the CMB controller, and then select EDA 1 from the right side, it is telling me that the Space required to program the V2 is 112%. I can remove some PIDs but the amount of space required never decreases in order to program the V2. Should I format Config file system to fix it?
    Thanks for any replies.
    EDIT: I finally realized that I had all of the other controllers selected too. I've got it going my way now.
  1. CSP5 and EDA Release for 06-07 Cummins
    By cindy@efilive in forum Cummins 5.9L
    Last Post: October 15th, 2013, 04:08 PM
  2. Data logging
    By dannyperform in forum General (Diesel)
    Last Post: June 21st, 2012, 04:45 AM
  3. help data logging
    By zbadestz in forum General
    Last Post: April 22nd, 2012, 02:14 PM
  4. data logging
    By ecc_33 in forum Duramax LB7
    Last Post: January 18th, 2012, 01:30 PM
  5. Data Logging Help
    By djfrazier in forum Cummins 5.9L
    Last Post: October 17th, 2011, 01:25 AM
