Results 1 to 10 of 15
Thread: Need guidance with custom pid
    Mar 2007
    Default Need guidance with custom pid
    I have never had good results with logging EGTs. So I decided to scrap the old approach. I bought an AEM 30-5131 gage. It out puts a 5v signal that can be easily logged with external inputs on the V2. So far it is working great! My question is how do I write a custom pid to change the volts to Degrees F on my dash?
    The scale is 0* = .5v and 1800* = 4.5v.
    More info here. http://aemelectronics.com/files/inst...AE%20Gauge.pdf
    Oct 2006
    Should be simple since it is a linear output.
    ( EXT.ADn-0.5)*450
    Last edited by 5.7ute; June 5th, 2014 at 03:55 PM. Reason: wrong way round in expression.
    The Tremor at AIR
    Lifetime Member darcy's Avatar
    Feb 2012
    See page 5 of the manual that you've posted for the formulae.
    For Temp in F* : {EXT.AD1} * 450 -225
    For Temp in C* : {EXT.AD1} * 250 -143
    Mar 2007
    Thanks guys!
    It was right there in front of me. LOL
    You should be able to modify your current pid (with the above formulae) so that the one pid produces both *C and *F.
    Mar 2007
    I have not had a chance to alter the pid yet. Just referencing the voltage to the chart. Working great. To pulls with flawless EGT monitoring!
    Very please with the AEM hardware so far.
    Mar 2007
    OK not having much luck with creating the pid
    I keep getting error
    Error code: ERR_DUPLICATE/109
    Duplicate *UNITS: F.
    What am missing?
    # File details
    # This section defines various details about the file format.
    *FILE
    #Parameter Value Description
    VERSION 7.1.1 File version
    DECSEP . Decimal separator used in this file
    # Units
    # See sae_generic.txt for more information on the *UNITS section
    *UNITS
    #Code System Abbr Description
    F Imperial °F "Degrees Fahrenheit"
    # Add slot definitions here
    # See sae_generic.txt for more information on "SLOT" formats
    #Units Low High Fmt Expression
    *CLC-00-002
    F 0 1800 .1 "{EXT.AD1} * 450 -225"
    *PRN - Parameter Reference Numbers
    # See sae_generic.txt for more information on the *PRN section
    #Code PRN SLOT Units System Description
    CALC.AEM_EGT F066 CLC-00-002 °F Temperature "AEM EGT"
    Mar 2007
    Feb 2012
    Try putting the °F in inverted commas in both locations. ie "°F"
    °F units already exist (as F), so delete your definition of it.
  1. Custom pid for scanner.
    By J.Abbott in forum Petrol / Gas
    Last Post: March 14th, 2013, 12:50 PM
  2. How do you make a custom PID???
    By WiseGuyZ06 in forum General (Petrol, Gas, Ethanol)
    Last Post: October 10th, 2007, 11:20 AM
  3. Custom PID: What functions can you use?
    By 2002_z28_six_speed in forum General
    Last Post: September 3rd, 2007, 06:05 PM
  4. Why LM-1 Custom PID???????
    Last Post: June 4th, 2007, 12:52 AM
  5. Anyone made a custom mpg (or km/L) PID?
    By thunder550 in forum General
    Last Post: May 17th, 2006, 04:38 AM
