Hopefully a simple question but should the values read via these PIDs match the battery voltage i.e. are these PIDs just a measure of battery supply?
On my setup the voltage is dropping with RPM by about a 1V (13.5V - 12.5V). The log is consistent and repeatable each time.
I've measured at the battery and it's stable at ~14V (Alt charging) so if the above PIDs should match this or at least stay the same then I need to the check the PCM battery feeds.
I have a converted RX7 so it's possible there's a wiring issue or I just need to bypass the Mazda wiring for a more consistent feed.
