Results 1 to 3 of 3
Thread: GM.DYNAIRTMP_DMA to B4901 in Calc.pid file?
    Dec 2010
    Default GM.DYNAIRTMP_DMA to B4901 in Calc.pid file?
    In the Calc.MAFT and Calc.VET it talks about earlier OS that do not have
    6. The pid GM.DYNAIRTMP_DMA is not defined for OS's 19980100, 1998020, 19980400, and some others...
    but you can create a CALC.B4901 lookup pid instead, see the following alternate calc_pids.txt:
    calc_pids.txt <-- check that this contains the same B4901 data as your tune file.
    Is " <-- check that this contains the same B4901 data as your tune file." refering to B4901? The calc_pids file is
    "*CLC-00-260
    factor 0.0 1.0 .4 "lookup({SAE.MAF.gps}, 0,0.60010, 10,0.17139, 20,0.12842, 30,0.08594, 40,0.08106, 50,0.07129, 60,0.06201, 70,0.05469, 80,0.04736, 90,0.04297)"
    My .tun is
    LABELS Charge Temperature Blending (Factor)
    Grams/Second {link: SAE.MAF} Value
    0.00 1.000000
    10.00 0.687500
    20.00 0.472656
    30.00 0.407715
    40.00 0.319824
    50.00 0.265137
    60.00 0.189941
    70.00 0.145020
    80.00 0.125000
    90.00 0.095215
    100.00 0.075195
    110.00 0.069824
    120.00 0.060059
    130.00 0.060059
    140.00 0.060059
    150.00 0.060059
    Is this what needs to be changed in the Calc.pid file?
    EM, yes correct...
    your CLC-00-260 should look like this (matching your B4901):
    Code:
    *CLC-00-260
    factor      0.0   1.0    .4  "lookup({SAE.MAF.gps},  0,1.00000, 10,0.687500, 20,0.472656, 30,0.407715, 40,0.319824, 50,0.265137,  60,0.189941, 70,0.145020, 80,0.125000, 90,0.095215, 100,0.075195, 110,0.069824, 120,0.060059)"
    Dec 2010
    Thanks joe!
  1. calc.pid /sae.generic - pid resoultion question
    By cyipher in forum Gen III V8 Specific
    Last Post: February 6th, 2014, 01:00 PM
  2. DYNAIRTMP_DMA vs CHRGTEMP_DMA
    By redhardsupra in forum General
    Last Post: February 21st, 2011, 09:51 AM
  3. e38 dma pid SCALEDCORVE_ doesnt work plus a bad calc pid
    By ringram in forum FlashScan V2 BB Logging
    Last Post: November 30th, 2008, 11:28 AM
  4. A0014 vs. B4901/02
    By mistermike in forum General (Petrol, Gas, Ethanol)
    Last Post: April 15th, 2008, 10:51 AM
  5. Idle Tuning with new pids (calc pid file included
    By Dirk Diggler in forum General (Petrol, Gas, Ethanol)
    Last Post: October 4th, 2005, 02:06 PM
