Results 1 to 10 of 10
Thread: Cant open Com1. The system cannot find the file specified?
    Jun 2014
    Default Cant open Com1. The system cannot find the file specified?
    Hi All,
    my first post. I'm just using EFI live & laptop scanning for the first time,
    I have a vt 5.0 engine in a HQ panel Van.
    Ive selected the vt v8 (not ls1) from the available files. This is what I am getting:
    55:53.527: Initialising...
    55:53.528: Opening COM1 8228,8,N,1
    55:53.529: Can't open Com1. The system cannot find the file specified.
    55:53.707: Ready.
    57:36.814: Updating vehicle information...
    57:36.816: Opening COM1 8228,8,N,1
    57:36.816: Can't open Com1. The system cannot find the file specified.
    58:03.331: Opening COM1 8228,8,N,1
    Cheers, Scott
    Lifetime Member limited cv8r's Avatar
    May 2005
    What type of cable are you using? Have you gone into device manager to see what com port your cable is on/using?
    It's all good until it goes "Bang"
    Jun 2014
    Hi I got an ALDL cable of ebay some fella in WA. Ive changed to port 4 & get a whole bunch of meaningless info. Ive tried to post it but the site wont take most of my posts...
    Jun 2014
    port 4:
    05:20.059: Initialising...
    05:20.655: Opening COM3 8228,8,N,1
    05:20.880: Ready.
    07:50.282: Opening COM3 8228,8,N,1
    10:21.370: Start macro: Set air fuel ratio: AFR
    10:21.372: Synchronising ALDL communications...
    10:21.372: Waiting for heartbeat: $08,$55,$A3
    10:21.372: Waiting for Aldl bus silence of at least 10ms...
    10:21.484: Com timeout: Expecting frame header byte
    10:21.491: Synchronising ALDL communications...
    10:21.491: Waiting for heartbeat: $08,$55,$A3
    10:21.491: Waiting for Aldl bus silence of at least 10ms...
    10:21.609: Com timeout: Expecting frame header byte
    10:21.615: Synchronising ALDL communications...
    10:21.615: Waiting for heartbeat: $08,$55,$A3
    10:21.615: Waiting for Aldl bus silence of at least 10ms...
    10:21.734: Com timeout: Expecting frame header byte
    10:21.742: Stop macro: Set air fuel ratio: AFR
    10:50.175: Opening COM4 8228,8,N,1
    11:13.022: Start macro: Set air fuel ratio: AFR
    11:13.024: Synchronising ALDL communications...
    11:13.024: Waiting for heartbeat: $08,$55,$A3
    11:13.024: Waiting for Aldl bus silence of at least 10ms...
    11:13.121: Send: $F5,$65,$04,$00,$00,$00,$00,$00,$00,$00,$00,$00,$0 0,$00,$00,$C4,$00,$93,$4B
    11:13.132: Error: Reply frame checksum failure
    11:13.156: Error: No echo received from MAX232
    11:13.168: Error: Reply frame checksum failure
    11:13.172: Send: $F5,$57,$01,$00,$B3
    11:13.294: Com timeout: Data frame truncated: $D3,$F5,$57,$01,$00,$B3,$F5,$98,$01,$00,$00,$00,$0 0,$2E,$76,$94,$51,$00,$00,$00,$00,$14,$00,$25,$00, $2E,$00,$07,$76,$76,$80,$80,$80,$80,$00,$00,$03,$9 2,$74,$FF,$80,$00,$0A,$00,$00,$0C,$6A,$00,$00,$00, $00,$4F,$00,$31,$6E,$9E,$00,$00,$00,$00,$00,$00,$0 0,$00,$00,$00,$00,$00,$00,$00,$00,$FF,$C5,$0F,$01, $27,$08,$55,$A3,$00,$00,$00,$00,$00,$00,$00,$00,$0 0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00, $00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$0 0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00, $00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$0 0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00, $00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$0 0
    11:13.299: Error: No echo received from MAX232
    11:13.418: Com timeout: Expecting frame header byte
    11:13.421: Send: $F5,$57,$01,$00,$B3
    11:13.432: Error: Max232 echo: $40,$58,$51,$12,$43,$C2 did not match command: $F5,$57,$01,$00,$B3
    11:13.458: Recv: $41,$63,$00,$00,$00,$58,$3C,$00,$00,$01,$F2,$C5,$0 0,$00,$10,$56,$AA
    11:13.461: Send: $F5,$57,$01,$00,$B3
    11:13.472: Error: Reply frame checksum failure
    11:13.477: Error: No echo received from MAX232
    11:13.490: Error: Reply frame checksum failure
    11:13.493: Send: $F5,$57,$01,$00,$B3
    11:13.503: Error: Max232 echo: $D8,$55,$D3 did not match command: $F5,$57,$01,$00,$B3
    11:13.518: Error: Reply frame checksum failure
    11:13.524: Send: $F5,$57,$01,$00,$B3
    11:13.535: Error: Reply frame checksum failure
    11:13.541: Error: No echo received from MAX232
    11:13.554: Error: Reply frame checksum failure
    11:13.556: Resuming normal ALDL communications...
    11:13.567: Error: Max232 echo: $40,$58,$51,$12,$43,$C2 did not match command: $F1,$56,$09,$B0
    11:13.596: Stop macro: Set air fuel ratio: AFR
    May 2005
    Go to edit,properties,comms tab and see if the max232 echo box is ticked, check out pic.
    Jun 2014
    THE MAX232 IS TICKED. iM TRYING TO USE TUNERPRO ALSO. BUT i CANT MAKE HEADS OR TAILS OF IT. iM RUNNING SERIES 1 VT WITH A V6 CONVERSIONS BCM SIMULATOR - ONE FELLA SAID MAYBE EFILIVE DOESNT LIKE THE BCM SIMULATOR
    May 2005
    Are you trying to tune or scan with tunerpro? You could also try unchecking the echo box.
    Jun 2014
    Just tyring to scan
    Jun 2014
    I cant establish a link while using tunerpro
    May 2005
    For tunerpro you will probably need to look elsewhere for help, but you will need to use the correct ADX for scanning,not XDF which is used for tuning.
    Maybe do a google search for BCM simulators and see if other people are having similar problems.
  1. "system Cannot Find Specified File"
    By Schwanke Engines in forum FlashScan V2
    Last Post: February 4th, 2014, 03:21 AM
  2. Did system recovery on PC-now can't open files
    By 67SS509 in forum General (Petrol, Gas, Ethanol)
    Last Post: April 14th, 2011, 03:32 PM
  3. cannot open file
    By 1hotduramax in forum General (Diesel)
    Last Post: September 17th, 2008, 01:46 PM
  4. FlashScan Couldn't find a Cal file for a 2002 Sub
    By MN C5 in forum General (Petrol, Gas, Ethanol)
    Last Post: June 25th, 2007, 03:34 PM
  5. Can't Find sae_generic.txt file
    By VetPet in forum General (Petrol, Gas, Ethanol)
    Last Post: November 20th, 2005, 12:44 PM
