Page 1 of 5 123 ... LastLast
Results 1 to 10 of 41
Thread: Update: Jun 16, 2014
    Default Update: Jun 16, 2014
    The June 2014 public pre-release software is now available.
    Please download and install both the V7.5 and V8 software packages.
    Download V7.5 Software (92 MB)
    Download V8 Software
    (45 MB) Updated (June 18, 2014) - please re-download and re-install the V8 software.
    Release Notes:
    Release Notes.
    The FlashScan/AutoCal V2 firmware has been updated, the version number has been increased to V2.07.61, and the firmware date has been updated to June 16, 2014. You must update the firmware in your FlashScan and AutoCal device to V2.07.61 to maintain compatibility with the V7.5 software.
    IMPORTANT: The *.ctz and *.coz tune file formats have been updated. All existing *.ctz and *.coz files will continue to operate with the V7.5 and V8 software and with the FlashScan and AutoCal firmware. All new *.ctz and *.coz tune files that are saved using the following software or firmware versions: V7.5.7.259, V8.2.2.252, V2.07.61 (or later versions) will no longer be compatible with older software or firmware versions.
    That means if you are using this latest software version, then any tune files that you save may only be shared with other EFILive users who are using this latest (or a later) version of the software and/or firmware. For tuners that means making sure your customers' software matches the software and firmware version that you are using.
    Fixed Issues:
    1. Deleting calculated PIDs no longer causes an application crash when loading log files that reference those deleted PIDs.
    2. E69 tune files no longer report errors when being opened in the V8 software.
    3. Some LML table descriptions have been corrected.
    4. In the V8 Scan Tool, changes to the order of all PIDs and deletions of calculated PIDs in log files are now saved back into the log file when the log file is saved.
    5. The error message "Tune file is not compatible with current software version." has been fixed.
    Known Issues:
    Please post issues, questions, clarifications (large or small) in this thread.
    As issues are reported and confirmed they will be re-posted as "Known Issues" below.
    Version Numbers:
    After installing the latest release you should have the following software, boot block, firmware versions installed:
    EFILive V7 software: V7.5.7 Build 259
    To view the installed version, select Help->About (in the V7 Scan or Tune software).
    EFILive V8 software: V8.2.2 Build 252
    To view the installed version, select Help->About (in the V8 Scan and Tune software).
    Boot Block: V2.07.07 (Feb 07, 2014
    To view/update the Boot Block, Click the [Check Firmware] button in the V8 Scan and Tune software.
    Firmware: V2.07.61 (Jun 16
    , 2014)
    The EFILive Development Team
    Aug 2009
    A couple of stupid questions Paul
    I have 6-7 yrs worth of .tun files which I tend to use on a regular basis with V7.5 ( as we still cannot edit in V8 )
    Is there some sort of "batch file" converter on the horizon to say change these all to .ctz files ?
    I also noticed since the last couple of updates I can no longer save as .tun
    Quote Originally Posted by APS Luis View Post
    I'm not sure why you would want/need to change them all to *.ctz files immediately? You will still be able to open, display and edit *.tun files. Only when you got to save them they will save as *.ctz files instead of *.tun files.
    Is there any particular reason why you want/need to change over all your files right now?
    Junior Member Alexander's Avatar
    Nov 2012
    Hi, I installed all the latest updates. read the program from cars (control unit is licensed and configured by me earlier), save, but I can not write back. It does not matter I modify it or write down what subtracted. Updated first, then read and can not write (((I do something wrong?
    Quote Originally Posted by Alexander View Post
    No you haven't done something wrong, we have. Working on a fix asap.
    I had thought maybe we'd messed up the version checking, but I just tried doing exactly what you said you did, reading a file, editing it using V7, saving it again, then flashing it with V8 and there was no error message on our test system here.
    Can you please check that you are running the latest V7.5 software. Use the help->about option to verify that the version is V7.5.7 build 259.
    Lifetime Member Boost's Avatar
    Dec 2006
    Loving the new support, have been patiently waiting for A50 editing. Click image for larger version.
    8.7 @ 84 (1/8 mile) bolt-ons
    A couple of A50 OS's are mapped and will be going in to a closed beta soon.
    Mar 2009
    Any word on the 01 TCM files that don't have the new lockup tables in them? With my swap I am pretty well limited to the 01 OS, and really need those lockup tables.
    I'm not sure what I can do to change my response from here, from what I saw D70, M14 & M17 do not have these tables/parameters in them at all. N02, N25 & U24 are missing D5232 but have the other two (D5231 and D5233). All other OS's have the full set
  1. 2014 silverado
    By gypsy06vortecmax in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: July 13th, 2014, 03:22 AM
  2. Update: Jun 13, 2014
    Last Post: June 15th, 2014, 12:24 PM
  3. Update: Jun 10, 2014
    Last Post: June 12th, 2014, 10:48 AM
  4. 2014 gmc 5.3
    By dkeven@gmail.com in forum Petrol / Gas
    Last Post: May 23rd, 2014, 09:28 AM
