Can you please email me one of the *.ctz tune files that gives the error? Email to paul@efilive.com
I guess that brings up the question of how come they have the same lockup issues as all the rest? They must use a different limiting table than other years do. Guess I'm up that creek without a paddle as I can ONLY use the 01 OS with my swap and have it shift and function correctly.
We have confirmed that the error message "Tune file is not compatible with current software version." may be displayed when attempting to flash tune files using the V8 software. There is no workaround. This error will be fixed an a new update posted as soon as possible.
The error was caused by an incorrect build process that built a faulty installation file.
hey Paul Eric here with DuraBurb (the Duramax Suburban People)
just uninstalled and reinstalled V8 (updated) but when opening tunes (.CTZ) from Duramaxtuner we still get a error for "tune file not compatible"
is there something tuners need to do before sending out tunes?
Boot Block is still showing 2.07.07 Feb 16 2014
Firmware is showing 2.07.61 Jun 16, 2014
UPDATE:
Full reboot of PC and V2 and we are back up and running Anyone with this issue just do a full reboot with the Updated V8 that gets everything working again.
Eric Swanson
DuraBurb Service Dept
