Results 1 to 4 of 4
Thread: Values in tune being changed after saving and reopening tune
    Jun 2009
    Default Values in tune being changed after saving and reopening tune
    Just wondering if anyone else has seen this issue. It's a COS3 tune on 2002 OS. I'm inputting the new injector values, save the tune, reopen and the values have been automatically changed. I.e., minimum injector pulse width set to 0.125 ms and is changed to 0.121580 on its own. I've seen this issue when setting the stoich value, but since i run E85 (stoich AFR 9.76) that had to do with going below the hard limit of the PCM I believe. Any input?
    Due to binary quantization (i.e. can only represent discrete values in binary, can't represent real values), the tunetool is saving the closest representation to what you entered.
    as a crude example, let's say:
    0.5 is represented as 0.100,
    0.25 is represented as 0.010,
    0.125 is represented by 0.001,
    then 0.625 is 0.101 and 0.75 is 0.110... but there is no exact representation for any values in between... e.g. the closest to 0.65 is 0.625 (0.101).
    Oct 2006
    Exactly as Joe said.
    In your example, the pcm is using a value of 0.015198 as the scaler.
    When you enter 0.125 as the parameter value (which would be 8.2 from the scaler), the pcm will round this to the nearest value (8 at the parameters address.) So when you next open the file the value of the parameter will be shown as 0.12158.
    The Tremor at AIR
    Jun 2009
    Thank you the responses. Makes good sense.
  1. Saving a tune thats already on the truck
    By caleb_duramax in forum Diesel
    Last Post: May 27th, 2014, 12:42 PM
  2. Advanced Camshaft Timing What needs to be changed in tune???
    By inputapmech in forum Gen III V8 Specific
    Last Post: October 11th, 2013, 07:32 PM
  3. Uploaded Tune But Nothin Changed
    By Caper01 in forum General (Diesel)
    Last Post: September 26th, 2009, 01:39 AM
  4. Saving Stock Tune File Help
    By VETTEMASTER in forum E37, E38 & E67 PFI ECM's
    Last Post: December 1st, 2007, 09:54 PM
  5. Have question about installing new update it changed my tune
    By 02pewterls1 in forum General (Petrol, Gas, Ethanol)
    Last Post: February 10th, 2005, 09:07 PM
