Results 1 to 7 of 7
Thread: 2014 5.3l sierra magnacharger
    May 2012
    Default 2014 5.3l sierra magnacharger
    i purchased a magnacharger kit for a 2014 sierra , they ask me to send the ecm to be tuned, im in mexico, so it will take some days.. does anyone can share a stock magnacharger tune so i can drive the truck
    May 2012
    STOCK AND MODIFIED TUNE, any suggestion? any help? ill apreciate it
    May 2012
    a couple of logs with the modified tune, overall truck feels good, things i notice is some bouncing in part throttle and litle knock in WOT
    May 2012
    any help
    Jul 2003
    What do you want to accomplish??? was it tuned by anyone already?
    May 2012
    I want it to be tuned as it should be..
    One of my friends send me the modified tune.. but on part throttle something weird happens with the throttle %, it goes up and down even if i keep the pedal steady, and that make the truck bounces.. on wot sometimes it runs strong sometimes not, it turns on 2 codes, intake airflow performance and tps, but im shure it has to be because of the tune
    Apr 2007
    Quote Originally Posted by 400ss View Post
    any help
    To get rid of some of the WOT KR---Most guys are deleting out all the "Cam Phaser Timing " above 3200 RPM's ---Can be from 2-4*
    Also--On other E92 SC tunes I don't see anyone changing the "MAP sensor scaler" beyond the stock #'s
    I see you changed many of the VE tables as well---I don't see this being done other than on dedicated race cars
    Same for the 2 throttle threshold tables
    I would try to set all this stuff back to STOCK and see if the throttle weirdness goes away
    Ramp in fuel factor is way to low---- I see and use 1.75-1.95
    Finally 12.10 -12.30 seems very rich for a SC DI engine--Most are around 12.7 which is considered VERY SAFE
  1. Magnacharger use EFI Live?
    By FreshDA9 in forum Gen III V8 Specific
    Last Post: July 11th, 2016, 06:51 AM
  2. can i run the maf with the magnacharger ?
    By supershift67 in forum Gen III V8 Specific
    Last Post: October 16th, 2015, 09:02 AM
  3. Cant open e92 2014 sierra tune file on v7
    By 400ss in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: April 10th, 2014, 10:51 AM
  4. 06' 6.0L w/ Magnacharger
    By BlackSS in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: February 3rd, 2011, 04:35 PM
  5. Magnacharger
    By caver in forum General (Petrol, Gas, Ethanol)
    Last Post: September 20th, 2005, 02:07 AM
