Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
Thread: A50 tuning
  1. #21
    May 2008
    Oh Ok so is this not released to us yet? or do i need to obtain a different OS we have have access too. thanks.
    2015 3500HD crew cab long bed, 6" fabtech, slightly tuned, emissions intact.
    2005 dmax ccsb, EFI live tuned DSP 5 Full built motor, S471 billet single, More better built trans this time. and lots of other things.
    1984 CJ7 powered by a 2000 LS1. 4L60E.
    2012 Jetta TDI 6 speed manual, (yes the dirty the bastard haha)
    2003 Jetta TDI,
    1986 K10 LQ4/4L80E
  2. #22
    Nov 2005
    A50 is presently in development. A few OS's have been mapped (but haven't made it into beta), others cannot be mapped due to changes made within the ECM/OS structure.
    Cheers
    Cindy
  3. #23
    May 2008
    Got it. that's what I figured.*thanks.*
    2003 Jetta TDI,
    1986 K10 LQ4/4L80E
  4. #24
    Lifetime Member DURAtotheMAX's Avatar
    Nov 2005
    Cindy there was a mid-year change to the LML TCM. The 2015.5+ trucks with the RPO code "AVF" have a digital/DC output speed sensor instead of the normal AC variable reluctance type sensor that has been used forever. The 2015.5+ w/ AVF TCM's have different wiring too (IE, if you compare the pinouts side by side of 2015 and older and 2015+ w/ "AVF") there are differences.
    I might even guess that MAYBE the hardware might be updated/different too...because looking at the pinouts, some things dont even come close to matching up (IE, on the 2015.5+ trucks, a certain pin is "ignition hot +12v feed", and the other 2015 and older w/o AVF TCM, its a pin for something significantly different such as a speed sensor, or a low-side driver for one of the solenoids.
    Ben
    2005 Silverado, CC/SB, 4x4, LT, LILLY/Allison
    12.9s @ 108 mph
    many thanks to Ross and Paul
  5. #25
    Lifetime Member Dmaxink's Avatar
    Nov 2009
    Quote Originally Posted by DURAtotheMAX View Post
    Ben
    Killer info, thanks Ben!
    -Kory
    I'm out of ideas? Nah trick... When in doubt, 0xFFFF it out!
    http://www.PPEI.com/
  6. #26
    Quote Originally Posted by Dmaxink View Post
    I think Ben works at Allison, he's just not letting it be officially known
  7. #27
    Nov 2005
    Haha I wish...then I would know how to map DTC's on the Allison TCM's!
    12.9s @ 108 mph
  8. #28
    Nov 2009
    You don't need to work for Allison for that one... Mapping DTC is pretty easy, just time consuming!!! Lol
    -Kory
  1. A50 tuning status?
    By Hotrodcorvette in forum Allison 5 & 6 Speed
    Last Post: February 9th, 2014, 12:28 PM
  2. Replies: 10
    Last Post: June 16th, 2013, 12:36 AM
  3. Help with TCM tuning on 2010 LMM code says doesnt support A50
    By darins28 in forum Allison 5 & 6 Speed
    Last Post: April 24th, 2013, 12:27 AM
  4. anyone have a 2009+ A50 TCM file??
    By DURAtotheMAX in forum Allison 5 & 6 Speed
    Last Post: August 20th, 2010, 12:51 PM
