Results 1 to 8 of 8
Thread: flash the .ctz file using V7.5
    Oct 2006
    Default flash the .ctz file using V7.5
    Hi, l am trying to open a .ctz file with 7.5 and fsp v1.2 and l get a "not support by this version of the software"....any help please....thankyou
    Diesel Forum Support Site Admin
    Nov 2005
    What version of V7 are you using? Please list the build number.
    Note: if the file you are using is created in the current pre release and is being attempted to be opened in an older software version you will be restricted. Ctz file functionality has changed and are no longer backwards compatible.
    Cheers
    Cindy
    Oct 2006
    Sorry l should have included more...version 7.5.7 build 245 however previous was build 258....thank you for the quick reply....
    Nov 2005
    Are you still having issues even after updating or is it now resolved?
    Cheers
    Cindy
    Oct 2006
    Good morning, still can not access the file....and the file was modified by a professional installer and then emailed to me (l am very grateful).....It keeps saying the version of the file is not supported...
    Nov 2005
    Quote Originally Posted by shihan View Post
    You will need to speak with your professional tuner and determine what version of software he is using.
    If the tune was created in a more recent version, you will get that error, the files are not backwards compatible between versions. Build 260 is the current version https://forum.efilive.com/showthread...te-Jun-21-2014
    What vehicle is the tune for?
    Cheers
    Cindy
    Oct 2006
    Problem is resolved today with the most recent update......thankyou Cindy for your help and support....last question...with the next update will this happen again? one must question the disabling of the software....again thankyou for your help....
    Nov 2005
    It's not often that software becomes backwards incompatible, but sometimes it is necessary.
    V7 software is being replaced. As functions are developed for V8, if we can port those developments into V7 for our FlashScan v1 customers to make a more stable and sound product for when product support for V7 is retired we will.
    .ctz file formats have been in use for a number of years (about 3 years) Given the dual purpose of .ctz files (with V7 and V8), and the distinct advantages .ctzs offer, it consumes too much time to support a similar function with less features like .tun files that only serve a small proportion of our customer base.
    We understand some people don't like change, which is why the features were concurrently available for a number of years bore this retirement.
    Cheers
    Cindy
  1. can a Flash Scan V1 flast a .ctz tune?
    By mtomac in forum FlashScan V1
    Last Post: June 14th, 2014, 02:09 PM
  2. Any E92 .tun or .ctz files etc about to have a look at?
    By ringram in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: August 18th, 2013, 12:31 AM
  3. E39A ctz file for Opel Insignia
    By madia in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: July 31st, 2013, 07:40 PM
  4. so i went to flash in a file and its a no go????
    By C Murda in forum Cummins 6.7L
    Last Post: May 10th, 2013, 12:16 AM
  5. Files in CTZ or CTD
    By Mike@Vengeance in forum AutoCal
    Last Post: May 8th, 2012, 12:11 AM
