The June 2014 public pre-release software is now available.
Please download and install both the V7.5 and V8 software packages.
Download V7.5 Software (92 MB)
Download V8 Software (45 MB)
Release Notes:Release Notes.
The FlashScan/AutoCal V2 firmware has been updated, the version number has been increased to V2.07.62, and the firmware date has been updated to June 21, 2014. There has been no actual change to the firmware since the previous (V2.07.61) version. The updated version number is for internal tracking/compatibility/consistency only.
IMPORTANT: The *.ctz and *.coz tune file formats were updated in the previous update. All existing *.ctz and *.coz files will continue to operate with the V7.5 and V8 software and with the FlashScan and AutoCal firmware. All new *.ctz and *.coz tune files that are saved using the following software or firmware versions: V7.5.7.259, V8.2.2.252, V2.07.61 (or later versions) will no longer be compatible with older software or firmware versions.
That means if you are using this latest software version, then any tune files that you save may only be shared with other EFILive users who are using this latest (or a later) version of the software and/or firmware.
For tuners that means making sure your customers' software matches the software and firmware version that you are using.
Fixed Issues:
- The PID display sequence in the V8 Scan Tool was not being saved/loaded correctly.
- Some E86 calibrations that displayed incorrectly have been fixed.
- Some E39, E78, E83 and E92 calibrations that displayed incorrectly have been fixed.
- Configuring LMM PID linking between the V7 Scan Tool and Tuning Tool software requires that you copy the existing LBZ_Link.ini file to a new file called LMM_Link.ini. The section name in the new LMM_Link.ini file must also be changed to [LMM].
Known Issues:Please post issues, questions, clarifications (large or small) in this thread.
As issues are reported and confirmed they will be re-posted as "Known Issues" below.
Version Numbers:
After installing the latest release you should have the following software, boot block, firmware versions installed:
EFILive V7 software: V7.5.7 Build 260
To view the installed version, select Help->About (in the V7 Scan or Tune software).
EFILive V8 software: V8.2.2 Build 253
To view the installed version, select Help->About (in the V8 Scan and Tune software).
Boot Block: V2.07.07 (Feb 07, 2014)
To view/update the Boot Block, Click the [Check Firmware] button in the V8 Scan and Tune software.
Firmware: V2.07.62 (Jun 21, 2014)
The EFILive Development Team
