Results 11 to 20 of 21
Thread: Update: Jun 21, 2014
    Senior Member garrettg.bpd's Avatar
    Jun 2013
    firmware date 6/21/2014
    EFILive Beta Tester
    2006 DODGE RAM 2500 4X4 Industrial Injection R1 100HP Injectors and BAG-O-PARTS, ATS Exhaust Manifold, AFE 67MM Turbo and MANIFOLD
    Quote Originally Posted by garrettg.bpd View Post
    Im using firmware v2.07.62. The date stamp on CMB.pmm is 6/20/2014 8.57 p.m.
    Not sure how the date/time stamp works when moving files from here (GMT+10 hours) to the US (probably about GMT-10 hours). It could cause the date/time stamp on your file to be 15..20 hours behind the time/stamp on the file I have here. The tell-tale is the minutes are the same at 57 minutes.
    Can you please read the CMB.pmm file from your FlashScan using EFILive Explorer and send me that exact file? Send to paul@efilive.com
    Jun 2013
    sent
    EFILive Beta Tester
    sent
    The CMB.pmm file that you sent me is the correct file. The data logs should be created with PIDs with prefix "CM". I am not sure why that is not the case on your device.
    Can you try BB logging again and see what prefix is on the PIDs in the *.efi log file?
    Jun 2013
    I just tried logging. Tried passthru and bblogging and both went fine. Not sure what the problem was with that first log. I still cant view the log I posted on the forum. But you fixed that file for me. It was the first log I did after the update. maybe the software was a little unstable. I don't thank I restarted my pc after the update. I'll keep an eye on it and see if it happens again.
    thanks
    CMB_0011.efi test pt log.efi
    EFILive Beta Tester
    Dec 2012
    A good restart after installs always seems to work wonders.
    Josh
    '04 GMC LLY
    Nov 2005
    Release switched from a pre-release to public release overnight.
    http://www.efilive.com/latest/softwa...e-jun-21-2014/
    Cindy
    Lifetime Member Rhino79's Avatar
    Jul 2006
    I received some .ctz files from a customer we sold an autocal to and EFILive wont open them, any idea whats going on there?
    Head Calibrator
    Gwatney Performance Innovation
    Jacksonville, AR 501-982-2102
  9. #19
    Quote Originally Posted by Rhino79 View Post
    Its possible that the customer is using updated software and you have not updated your software to match the version your customer is using.
    See the message on this page for more info: http://www.efilive.com/latest/softwa...e-jun-21-2014/
  10. #20
    Jul 2006
    Thanks Paul, that did the trick!
    Head Calibrator
  1. 2014 silverado
    By gypsy06vortecmax in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: July 13th, 2014, 04:22 AM
  2. Update: Jun 16, 2014
    Last Post: June 20th, 2014, 02:51 PM
  3. Update: Jun 13, 2014
    Last Post: June 15th, 2014, 01:24 PM
  4. Update: Jun 10, 2014
    Last Post: June 12th, 2014, 11:48 AM
