Results 1 to 10 of 14
Thread: E40 SPeed Density tune won't accept TCS Patch.....Traction Service light
    Senior Member mowton's Avatar
    Oct 2008
    Default E40 SPeed Density tune won't accept TCS Patch.....Traction Service light
    Having a heck of a time trying to figure out why the attached tune wont respond to the TCS Patch in our Speed density tune. Have tried several attempts at full flash but just cant get it to take?
    Please help as the customer is chomping at the bit to get his car back.
    Thanks,
    Ed M
    Ed, I am not sure why that is happening, I checked the patch in your file and it is correctly applied. Essentially the E40 has not been modified in EFILive since about 2009 (and that had nothing to do with OS patches), so that either means your car has some other issue or you are the first to use the TCS patch on this OS in 5 years
    Oct 2008
    Thanks Ross, it was a panic cry on Friday and after a settle down with a scotch, I also thought we needed to look about as we to have not ever had an issue with at least 2 dozen E40 Speed density setups in the past. Thank you for at least validating the patch. Will look a bit deeper Monday morning and report accordingly.
    Ed M
    Oct 2008
    So as a follow-up, the car came in with a HPTuners 2 Bar Speed Density tune and apparently no Traction Control issues. Burned a license to reload file just to verify and low and behold Traction Control on-off ok, Dash icon off and no C0256 code. This OS also has a TCS Patch as well.
    Today we will re-program via Tech 2 the EFILive Program and begin looking for possible causes.
    Ed M
    Oct 2008
    Reprogrammed the car with the tech 2 and updated new stock file with the above tune parameters with same results. Trying to tune out any possible torque management issues (only other help I could find during my search) that might be disabling the Traction Control in the above tune. I personally don't understand why this is so difficult when the patch alone should be the remedy.
    Are there any DTC's that require disabling?
    Frustrated...............
    Ed M
    All that patch is doing is stopping the ECM setting a flag to say the torque calculations will be inaccurate due to a MAF error. Out of interest if plug plug the MAF in does the Traction Light go away?
    Oct 2008
    Ross, the setup does not have a MAF installed. Might there be a need to terminate the harness wires some way. As i stated, the hptuners file operates the traction control as designed? I tried today again to max the traction control tables with no luck.
    Thanks,
    Ed M
    No need to terminate the MAF, I was just wondering if that was the reason behind it or if there is some other issue tripping the problem.
    I would compare the traction tables in the HPT file to yours, sometimes maxing those can upset things too.
    Oct 2008
    I actually did that today, updated the above file with each of the applicable HPTuner values with no success. Really at a loss now :-(
    Ed, what happens if you do nothing more than turn off the MAF MIL codes, and apply the TCS patch?
  1. E38 SD TCS Patch Issues
    By swingtan in forum E37, E38 & E67 PFI ECM's
    Last Post: April 22nd, 2012, 01:17 AM
  2. OS 12647991 TCS Patch
    By JezzaB in forum E37, E38 & E67 PFI ECM's
    Last Post: February 14th, 2012, 06:38 PM
  3. RR won't accept any tune from EFILive but fine from Tunercat and EMUtility
    By N0DIH in forum RoadRunner Real-Time PCM Emulator
    Last Post: November 23rd, 2011, 09:17 PM
  4. Please explain what happens with a TCS patch!
    By Redline Motorsports in forum E37, E38 & E67 PFI ECM's
    Last Post: November 30th, 2008, 06:33 PM
  5. Speed Density Charge Temperature Blending (E40)
    By Gelf VXR in forum Gen IV V8 Specific
    Last Post: June 28th, 2008, 04:36 PM
