Results 1 to 10 of 12
Thread: 4L60E not holding first gear when shifter set at 1st.
    Mar 2012
    Default 4L60E not holding first gear when shifter set at 1st.
    Hi all.
    I am trying to sort out an issue I am having with my 4L60E.
    As the title mentions I have the shifter set on 1st and do a power run (drag run) but the car will automatically shift to 2nd at 3900rpm (44km/h) which is way too early!
    Ideally I would like the car to hold first until approx. 6000rpm.
    Any ideas where I should be looking in the tune to adjust the shift point for first gear hold?
    I have attached my tune for you to look at. I have also attached a screen shot of when it all happened. Could it possibly be that I had not achieved WOT? I had 63.9% throttle but I would assume the car would hold 1st if first is selected.
    Thanks in advance.
    Mark
    D0913: set this higher.
    Aug 2010
    Hi Mark,
    Are you running a 32 inch tire with 4.11 gears ?
    Do you have an OEM gear position switch (PRNDL) assembly mounted on the 4L60, and wired to the PCM ?
    Taz
    Mar 2012
    Hi taz.
    Yeah its a 31" tire and 4.11 lsd. Your right about the gear position switch also. All stock and wired to the pcm.
    Why do you ask mate?
    Thanks.
    Mar 2012
    Hi Joe.
    I looked at that earlier after doing a search on the forum. D0913 is set at 88kmh already. My car is shifting at 45kmh odd. I had ignored this parameter as I thought this wouldnt be the issue?
    Aug 2010
    Quote Originally Posted by barbermi View Post
    ... its a 31" tire and 4.11 lsd. Your right about the gear position switch also. All stock and wired to the pcm.
    Why do you ask mate? ...
    Hi Mark,
    Just attempting to eliminate variables. If the gear and tire information is correct, the reported / calculated vehicle speed should be correct. If you have a PRNDL switch wired, the PCM should "know" what gear position the shifter has been placed.
    Your WOT TPS thresholds are defined by D1206 to D1211. Given your TPS% was in the 60% range in the attached screenshot, the PCM would have been using the part-throttle shift speeds.
    The attached tune should rectify your selected gear position issue - and should now hold whatever gear you select - as all 4L60s will do (unlike the 4L80s).
    Also, I sanitized some of the shift speeds, but did not go through your tune completely.
    Taz
    Mar 2012
    Thanks Taz.
    Ill give the tune a shot tomorrow.
    Had the tune I been running set up as a 4l80? I didn't think that would be possible?
    I am confident the speed calibration is accurate as I have checked the Vss against a GPS speed indicator and it looks within a couple km/h.
    Thanks again for your time.
    Mark
    Aug 2010
    No sir - was not setup as a 4L80 - was correctly setup as a 4L60. I was just highlighting platform differences for anyone following along, as 4L60 vs 4L80 can present different tuning challenges.
    Taz
    Mar 2012
    TAZ your a true gentleman!
    Thankyou for your help with the first gear hold. It works an absolute treat. At WOT it holds gear until the limiter! Now I need to stop it spinning the wheels! Haha.
    Out of curiosity? could the tune be set up to do the following at the drags:
    Shifter in D1 take off and the car automatically shifts to second at say 6200rpm. Once it shifts I move the shifter to D2. It holds second until 6000rpm then shifts itself to 3rd I move the sifter to D3 and so on. In theory wouldnt this make for the most consistent ET's? Provided traction etc is constant.
    Just a thought anyway.
    You will get more consistent ET with hands-off... i.e. set up the WOT RPM and MPH tables to shift at the RPM you require.
  1. 4l60E W/ Rachet shifter want it to hold geart till i change and still keep D function
    By HellKnightHicks in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: June 29th, 2014, 10:41 AM
  2. Holding REVs when changing Gear
    By bluey in forum General (Petrol, Gas, Ethanol)
    Last Post: November 2nd, 2013, 10:18 AM
  3. Holding 4th gear for Dyno
    By Matt68 in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: May 30th, 2011, 03:59 PM
  4. Stuck in 1st Gear!
    By TBMSport in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: November 4th, 2010, 08:11 PM
  5. making auto stay in 1st gear
    By minytrker in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: July 10th, 2006, 01:05 AM
