Thread: 07 L92 with 2011 6L90
    Jul 2014
    Cool 07 L92 with 2011 6L90
    Hi new to the forum need some help build a 70 chevy truck put in a l92 with mast motorsports ho cam transmission 2011 chevy 2500 6l90 the ecm for the trans is 12642100 need help tuning engine and trans
    Aug 2010
    That ECM (12642100) is a 2011 E78. I don't work with those ECMs at all. There are a few people on the Forum who do, but support for that ECM is somewhat limited currently.
    Given that this is a custom vehicle (1970 Chev Truck - a favorite of mine !), it may be easier to use an E38 or an E67 ECM.
    Just some thoughts ...
    Jul 2014
    Hi Thank for the infor
    Jul 2014
    Hi ok can I run my 2011 6L90 with a 2010 ECM 12625455 along with my l92
    Aug 2010
    It just occurred to me from reading your posts, that you may be operating under the belief that the L92 and 6L90 are controlled jointly - they are not. The 6L90 has its own TCM (a T43), which is located inside the transmission itself (you can see it if you remove the transmission oil pan). The engine (your L92, or any Gen IV engine) has its own ECM - which could be an E38, E67, or E78.
    ECM 12625455 is a 2009 E38. It is not an ideal choice for this project.
    The 2011 6L90 is probably running OS24256125 - which was common to trucks, Camaro, Corvette, and CTS-V in 2011. If you choose to move away from your existing 2011 E78 ECM (which in the long run would make tuning easier), I would recommend using a 2010+ ECM.
    2010+ E38 uses service number 12633238.
    2010+ E67 uses service number 12633264.
    Using an E38 would provide you with the option of using a Corvette APP (gas pedal) and TB (throttle body), as many people view the Corvette APP as easier to mount / adapt.
    Using an E67 would allow Cruise Control to become an option.
    Either way, you will probably require the services of a professional tuner, or a very accommodating GM dealer, to load the correct base calibration into the ECM.
    Just some options to consider ...
    Jul 2014
    Thank everyone I appreciate the info I have a 2010 truck wiring harness with x1 & x2 look like I'm will be use the 12633238 ecm how need to find
    a VIN# to work with l92 with mast motorsports HO cam & 2011 chevy truck 6L90
  1. T43/E38 6L90 Shift points change
    By 55chevdelray in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: September 16th, 2020, 08:58 PM
  2. Shift point change fro 6L90
    By 55chevdelray in forum Petrol / Gas
    Last Post: May 20th, 2013, 12:48 PM
  3. 6l90 to 6l80?
    By VEGASROBBI in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: June 16th, 2012, 12:13 PM
  4. January 31st 2011 pre-release (Updated Feb 03, 2011)
    Last Post: February 24th, 2011, 05:14 PM
  5. LS376/480 and 6L90
    Last Post: June 11th, 2009, 08:42 AM
