Results 1 to 1 of 1
Thread: Update: Jul 07, 2014
    Default Update: Jul 07, 2014
    This update has been released to correct the known issues listed here
    If you have recently updated your software, you may be able to use the "Check for Updates" option to update your existing V7.5 and V8 software installations. Or you may choose to download and install both V7.5 and V8 software packages using the links below.
    Note: Only the V8 software was updated in this release. If you have already installed the July 04 update (V7.5.7.261), then you do not need to download and install the V7.5 software from this release.
    Download V7.5 Software (94 MB)
    Download V8 Software
    (46 MB)
    Release Notes:
    Release Notes.
    The FlashScan/AutoCal V2 firmware has been updated, the version number has been increased to V2.07.63, and the firmware date has been updated to July 02, 2014.
    IMPORTANT: The *.ctz and *.coz tune file formats have been updated. All existing *.ctz and *.coz files will continue to operate with the V7.5 and V8 software and with the FlashScan and AutoCal firmware. All new *.ctz and *.coz tune files that are saved using the following software or firmware versions: V7.5.7.259, V8.2.2.252, V2.07.61 (or later versions) will no longer be compatible with older software or firmware versions.
    That means if you are using this latest software version, then any tune files that you save may only be shared with other EFILive users who are using this latest (or a later) version of the software and/or firmware. For tuners that means making sure your customers' software matches the software and firmware version that you are using.
    Fixed Issues:
    1. Saving tune files from the V8 software incorrectly required a FlashScan device to be connected even when no security restrictions are active.
    Added Features:
    1. None.
    Known Issues:
    Please search for existing known issues here:
    https://forum.efilive.com/showthread...e-and-firmware
    Please post new issues, questions or clarifications (large or small) in this thread.
    As new issues are verified they will be posted in the "known issues" thread above.
    Version Numbers:
    After installing the latest release you should have the following software, boot block, firmware versions installed:
    EFILive V7 software: V7.5.7 Build 261
    To view the installed version, select Help->About (in the V7 Scan or Tune software).
    EFILive V8 software: V8.2.2 Build 255
    To view the installed version, select Help->About (in the V8 Scan and Tune software).
    Boot Block: V2.07.07 (Feb 07, 2014
    To view/update the Boot Block, Click the [Check Firmware] button in the V8 Scan and Tune software.
    Firmware: V2.07.63 (Jul 02
    , 2014)
    The EFILive Development Team
  1. Known issues with Jul 07, 2014 release of the EFILive software and firmware.
    Last Post: July 10th, 2014, 10:12 AM
  2. Update: Jul 04, 2014
    Last Post: July 8th, 2014, 09:56 AM
  3. Update: Jun 16, 2014
    Last Post: June 20th, 2014, 02:51 PM
  4. Update: Jun 13, 2014
    Last Post: June 15th, 2014, 01:24 PM
  5. Update: Jun 10, 2014
    Last Post: June 12th, 2014, 11:48 AM
