Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Known issues with Jun 21, 2014 release of the EFILive software and firmware.
  1. #11
    Quote Originally Posted by wait4me View Post
    In EFILIVE Explorer.exe Files wont just drag into the flashing window, It shows no response and the files do not move over. HOWEVER, If you copy the files on the desktop you want over, then PASTE them into the bottom right window, it will load on with no issues.
    I can drag files from a folder in Windows Explorer to EFILive_Explorer and it works fine. Can you give any more details that will help me to reproduce the error you're seeing?
  2. #12
    Quote Originally Posted by comnrailpwr View Post
    Having issues with transferring files to autocal using quick setup (F:6) V8. Firmware and bootblock on both devices up to date. Latest builds software versions. When I use quick setup and attempt to flash truck (CMB) it errors $0502. Checked the config files with explorer and CMB_R.obj and CMB_F.obj were both there. If drag the file, saved for remote flashing with tune tool, to autocal using explorer like I always have done all is peachy. Any ideas?
    Can you please send the *.bbx quick setup file to me at paul@efilive.com so I can try and reproduce the fault?
  1. Update: Jun 21, 2014
    Last Post: June 30th, 2014, 11:49 PM
  2. Update: Jun 16, 2014
    Last Post: June 20th, 2014, 02:51 PM
  3. Update: Jun 13, 2014
    Last Post: June 15th, 2014, 01:24 PM
  4. Known issues with Nov 07 2013 release of the EFILive software and firmware.
    Last Post: June 14th, 2014, 10:53 AM
  5. Update: Jun 10, 2014
    Last Post: June 12th, 2014, 11:48 AM
