Results 1 to 6 of 6
Thread: 24 tooth to 58 conversion?
    Jun 2014
    Default 24 tooth to 58 conversion?
    I blew up the motor in my Trailblazer SS (aluminum 6.0, 24 tooth). It is not salvagable. I want to use just an iron 6.0 engine, and was wondering if we can reprogram the ECU to work with a potential 58 tooth wheel (opens more possibilities at salvage yards).
    Lifetime Member picnic_george's Avatar
    Jan 2007
    Use this
    http://www.lingenfelter.com/mm5/merc...gory_Code=C163
    No 24x pcm that I know of will run a 58x engine
    +1 on LPE 58x/4x->24x/1x converter.
    Senior Member J.Abbott's Avatar
    Aug 2010
    What controller is in your Trailblazer
    It would be an E40 for an 06 TBSS.
    Feb 2013
    Just change the reluctors and sensors... = 100% right and reliable, just done an LS1 to Gen4 this way and it runs/starts perfectly 0 issues.
  1. 58 tooth reluctor wheel in an 04' GTO?
    By PRAY in forum Gen III V8 Specific
    Last Post: June 12th, 2014, 03:51 PM
  2. Howto Roadrunner connection with Blue Tooth under Windows 7 ???
    By Treurentner in forum RoadRunner Real-Time PCM Emulator
    Last Post: May 19th, 2011, 03:00 AM
  3. Do I have a 24tooth or 58 tooth ECM?
    By matt in forum Gen IV V8 Specific
    Last Post: August 11th, 2009, 06:40 PM
  4. 58 Tooth Wheel Indexing
    By rv6ejguy in forum Gen IV V8 Specific
    Last Post: January 21st, 2009, 08:06 AM
  5. 58 tooth reluctor
    By v8vegaman in forum Gen IV V8 Specific
    Last Post: January 10th, 2008, 05:38 PM
