Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: E83 Full Flash
  1. #11
    Feb 2006
    does your cruze have the mylink system?
    mine does and it continues on the song every time. i.e doesn't start from start, it continues on from the second it turned off.
  2. #12
    Yes Mylink indeed, I have even tried a different USB stick, no luck. My kids laugh, every time we start the car they say, dad, is this the only song you listen to because 95% of the time it always reverts to the same song 'it' has chosen as the default start up song. I think mine might be slightly different to you because SatNav was not an option at all in the oil burners (much to my disgust).
    I remember the conversation with the sales guy.
    I'll have a Diesel with SatNav
    Sorry, SatNav is only in the SRiV
    No worries, I'll have an SRiV with a Diesel.
    Sorry, SRiV doesn't come in Diesel.
    (crickets chirping)
  3. #13
    Feb 2006
    interesting, maybe there is a setting somewhere in the mylink system that needs to be changed? the only thing I did notice when I tried to check for new firmware/software for some modules is the tis2web would say it couldn't talk to the module.
    worst was after flashing the bcm, it requires configuring afterwards... The setup/config does not work because tis2web fails on confirming the odo reading as it wouldn't talk to the ICC (instrument cluster).
    so I currently have no cruise control. the button to turn on works and lights up on the dash. but the set/resume button do nothing. something I will get fixed when it goes in for it's 15k service
  4. #14
    Quote Originally Posted by kangsta View Post
    does tactrix work ok with TIS2WEB?
    Quote Originally Posted by Tre-Cool View Post
    yep, I flashed the ecu and bcm in my cruze. checked the other modules to confirm they were the latest available too
    There is a modify button on the forum
    This is why we are held at ransom to the dealerships.
  5. #15
    Feb 2006
    mines a 2013 build so while its an sri-v it doesn't have satnav anyway. which is not really a big deal. u just use my phone and because of the Bluetooth sync it plays it back through the stereo anyway.
    Do your songs continue on via Bluetooth? (if you ever played them through your phone)
  1. I can't full flash with W8
    By Highlander in forum Petrol / Gas
    Last Post: January 3rd, 2013, 03:48 PM
  2. Why cant I full flash?
    By 01Blackerado in forum Gen III V8 Specific
    Last Post: March 17th, 2011, 10:11 PM
  3. Pre Full Flash to Full Flash Tune Question
    By Donovan in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 13th, 2010, 12:43 PM
  4. HELP cant full flash
    By Madspeed in forum Duramax LLY
    Last Post: April 23rd, 2007, 07:05 PM
  5. Full flash
    Last Post: June 11th, 2006, 06:28 PM
