Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Will the autocal work on the C7 with the E92
    Senior Member J.Abbott's Avatar
    Aug 2010
    Default Will the autocal work on the C7 with the E92
    I need to scan a car at the track. I just uploaded the E92 file and selected all my pids but when I scan I get a message like Mem pwr reqd.
    Any idea's and has anyone used and autocal on a C7 yet?
    Aug 2010
    I just went out and checked again the actual message is below
    ECM
    REQ PWR_M
    Senior Member garrettg.bpd's Avatar
    Jun 2013
    That pid is probably not supported by that ecm. Try removing that pids from your list and try again.
    EFILive Beta Tester
    2006 DODGE RAM 2500 4X4 Industrial Injection R1 100HP Injectors and BAG-O-PARTS, ATS Exhaust Manifold, AFE 67MM Turbo and MANIFOLD
    Aug 2010
    Quote Originally Posted by garrettg.bpd View Post
    I did not see anything in my pids listing that. I will check tomorrow when I have the car but I didn't not see anything listed in my pid list that resembled that.
    Any Ideas EFI Live?
    Quote Originally Posted by J.Abbott View Post
    ECM
    REQ PWR_M
    Whenever you start logging and the AutoCal displays a message with two lines:
    Line 1: Controller type
    Line 2: PID name
    In your case:
    ECM
    REQPWR_M
    That means the PID REQPWR_M is not valid for that ECM. Remove that PID and retry data logging.
    PIDs that end with _M are defined by EFILive per operating system, so it may be that PID has not been configured for the operating system in your E92. What is the operating system in your E92? I'll check to see if/when support for it will be available.
    Aug 2010
    Line 2: PID name
    In your case:
    ECM
    REQPWR_M
    Paul,
    I will go back and look at all the pids. I don't have my laptop in front of me but I will respond later tonight with OS. I have not been playing with the C7 much but now I am ready to get rolling quick. What do you need from us on the E92. Just email or message me that.
    Justin
    Zip
    Paul,
    Justin
    Zip
    Just the operating system number or better still, a copy of the *.ctz file that you read from the E92 ECM
    Aug 2010
    Ok found the pid, it is desired torque. that sucks I really would like to log that. Anyway I will email you the .ctz file.
    Aug 2010
    Removed the torque pid and it works.
    Aug 2010
    I don't remember if I sent you anything. I would still like that pid. However I have a new issue on a different C7.
    We are trying to log one at the track and I can't log E92 and T43 at the same time, is there a way to do this. I need to be able to log "current gear" along with everything else. Also I would like to log the odometer if possible so I can see in feet where the car is shifting.
    Justin
  1. E92 GM computer
    By joelp in forum Petrol / Gas
    Last Post: November 15th, 2013, 09:25 AM
  2. Will Autocal work with E78?
    By Patrick G in forum AutoCal
    Last Post: November 4th, 2013, 10:53 AM
  3. E92 Not being supported yet?
    By 05gmcsierra in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: October 15th, 2013, 04:13 PM
  4. Replies: 1
    Last Post: September 19th, 2011, 09:38 AM
