Results 1 to 10 of 11
Thread: Update: Jul 04, 2014
    Default Update: Jul 04, 2014
    This update has been released to correct the known issues listed here
    Please download and install both the V7.5 and V8 software packages.
    If you have already installed the June 21, 2014 software from our main web site downloads page, you can auto-update to this version using the "Check for Updates" option. You must perform both V7.5 and V8 "Check For Updates" options.
    Download V7.5 Software (94 MB)
    Download V8 Software
    (46 MB)
    Release Notes:
    Release Notes.
    The FlashScan/AutoCal V2 firmware has been updated, the version number has been increased to V2.07.63, and the firmware date has been updated to July 02, 2014.
    IMPORTANT: The *.ctz and *.coz tune file formats have been updated. All existing *.ctz and *.coz files will continue to operate with the V7.5 and V8 software and with the FlashScan and AutoCal firmware. All new *.ctz and *.coz tune files that are saved using the following software or firmware versions: V7.5.7.259, V8.2.2.252, V2.07.61 (or later versions) will no longer be compatible with older software or firmware versions.
    That means if you are using this latest software version, then any tune files that you save may only be shared with other EFILive users who are using this latest (or a later) version of the software and/or firmware. For tuners that means making sure your customers' software matches the software and firmware version that you are using.
    Fixed Issues:
    1. E86 calibration updates.
    2. *.coz files can now be added to BBX Quick Setup files.
    3. E69 BBL now logs data.
    4. Added cylinder knock PIDs for E55.
    5. Loading a BBX "Quick Setup" *.bbx file sometimes caused an Access Violation" error.
    6. Changing any DTC from Inactive to Active in LML tunes caused a "Range Error" (LML DTCs are only available on non-USA installations only).
    7. BBX "Quick Setup" was not copying tune files correctly to AutoCal.
    8. Fixed faulty calibration definitions for E38 OS 12618277.
    Added Features:
    1. A new file browse option to help make it easier to find tune files, is available here: [F8: Tools]->[F2: Search]->[Browse].
    2. A new option exists to allow tuners to hide the "Switch Tunes" menu item on AutoCal's "simple Menu" structure. [F6: Devices]->[F7: BBX]->"Black Box Options:"
    3. A new check has been added when flashing CMB files to prevent accidentally flashing CMB (5.9) files into CMC (6.7) trucks.
    4. The tune file history display now captures the software version and the calibration definition file version used to edit the tune file.
    Known Issues:
    Please search for existing known issues here:
    https://forum.efilive.com/showthread...999#post207999
    Please post new issues, questions or clarifications (large or small) in this thread.
    As new issues are verified they will be posted in the "known issues" thread above.
    Version Numbers:
    After installing the latest release you should have the following software, boot block, firmware versions installed:
    EFILive V7 software: V7.5.7 Build 261
    To view the installed version, select Help->About (in the V7 Scan or Tune software).
    EFILive V8 software: V8.2.2 Build 254
    To view the installed version, select Help->About (in the V8 Scan and Tune software).
    Boot Block: V2.07.07 (Feb 07, 2014
    To view/update the Boot Block, Click the [Check Firmware] button in the V8 Scan and Tune software.
    Firmware: V2.07.63 (Jul 02
    , 2014)
    The EFILive Development Team
    Lifetime Member wesam's Avatar
    May 2010
    When E78 OS 12657063 will be supported
    I contact support last year regarding this but it still not supported
    thanks in advance
    EFILive Tuner
    Nov 2005
    Quote Originally Posted by wesam View Post
    thanks in advance
    We posted the below in the June 10 software release thread.
    The line was drawn in the sand to get the release finalised. Unfortunately not all OS's were mapped. Remaining OS support and additional tables will start to filter into production software around August.
    Cheers
    Cindy
    May 2010
    Quote Originally Posted by cindy@efilive View Post
    Cheers
    Cindy
    Thanks a lot Cindy
    waiting for August
    EFILive Tuner
    Feb 2006
    Not a big issue, but I did send an email through to support on a bug/incorrect label for B5112 for 12654173 cal.
    efi has the vertical row from 0 when it should start at 1 and increment in say .050 eq ratios.
    Thanks.
    Lifetime Member Chavez91's Avatar
    Dec 2012
    Quick question.... was setting up an autocal in V8 and while choosing the PID sets to program to the autocal, I got an error message for "Out of Memory" .... which was kind of surprising. Opened command prompt and to my surprise EFI was hogging 1.8Gigs of RAM??? What would cause that? It usually runs with under 100MB of ram. I closed it and restarted the program (V8) and its back down to 45MB but was just something weird that happened.
    Josh
    '04 GMC LLY
    - L5P, Motech, 6-Spd Conv. ML Trans.
    '05 GMC LLY - 250%, 12mm, 67mm Custom Turbo, 6-Spd Conv. ML Trans
    '19 3500 RAM - Tuned Aisin 0_o
    Dec 2012
    Also trying to use the "Program Quick Setup" feature and I get a "Error: $0194: Write Failure." When its halfway through copying.
    Josh
    '04 GMC LLY
    Quote Originally Posted by Chavez91 View Post
    If you can reproduce the excessive memory usage, can you please document the steps required to reproduce it and log a technical support case here:
    https://support.efilive.com/kb_artic...7778-QEKN-0400
    That error message usually means the CONFIG file system on AutoCal (or FlashScan) is full. Try selecting the quick setup option "Format CONFIG file system before copying BBX setup files to device.". That will delete all existing data from the CONFIG file system. If it still fails with $0194 then it may be that you have too much data selected in the quick setup file.
  1. Update: Jun 21, 2014
    Last Post: June 30th, 2014, 11:49 PM
  2. Update: Jun 16, 2014
    Last Post: June 20th, 2014, 02:51 PM
  3. Update: Jun 13, 2014
    Last Post: June 15th, 2014, 01:24 PM
  4. Update: Jun 10, 2014
    Last Post: June 12th, 2014, 11:48 AM
