Results 1 to 7 of 7
Thread: Known issues with Jul 07, 2014 release of the EFILive software and firmware.
    Default Known issues with Jul 07, 2014 release of the EFILive software and firmware.
    Currently known issues and possible workarounds for the July 07, 2014 release of the EFILive V7.5.7.261, V8.2.2.255 software and the V2.07.63 FlashScan and AutoCal firmware.
    Issue 1:
    Workaround:
    None. It is a restriction of the *.efi (V7.5 log file format). That restriction will be removed and the TCM PIDs will display their true origin once the V8 scan tool software is available.
    Issue 2:
    Flashing an A50 controller using the V8 pass-thru or BBF option will fail with a $0331 error.
    Workaround:
    Download the attached A50_W.zip file and unzip it into the folder: \Program Files\EFILive\V8\Config. Make sure to copy that same file to the [CONFIG] file system on any AutoCal or FlashSCan devices that you use for Black Box Flashing of A50 controllers. Will be fixed in the next update.
    Issue 3:
    The [Search] button is hidden on the [F8: Tools]->[F2: Search] window.
    Workaround:
    1. Click the [Stop] button to give it focus.
    2. Press Shift+Tab to set focus on the hidden [Search] button (the search button is hidden behind the stop button).
    3. Press [Space bar] to start the searching.
    4. Click the [Stop] button to stop searching which hides the [Stop] button and makes the [Search] button appear again.
    Issue 4:
    Opening BBX setup files can result in memory leaks which can lead to instability and/or "out of memory" errors.
    Workaround:
    Try closing and re-opening the BBX window before opening a new BBX setup/configuration file.
    Aug 2004
    24236195 os for T42 has some things missing/and wrong starting locations for some tables.
    D4203 And the others, as you can see are way off,
    Also D3203 is missing for some reason. Third gear, 2nd and forth show up..
    T42 last changed 30th April, 2012, that OS was probably added years before that, seems really odd it is has been wrong for this long.
    Jan 2011
    I am seeing some instability (high memory utilization) with V8.2.2.255 (see screen capture attached). Seems to happen after I plug in an Autocal when I am in the BBX menu.
Name:	V8_2_2_255 high memory usage.jpg
    Jul 2014
    I am having issues loading BBX settings. Once I open the specific BBX and trying to program them, it prompts these error messages such as "Out of memory", "Argument out of range.", etc. EFILive Scan and Tune then becomes unresponsive. I have tried uninstalling and re-installing to no avail.
    Jul 2014
    Also receiving error message "Access violation at address 0040939A in module 'EFIlive_ScanAndTune.exe'. Read of address 032D1000.
    Quote Originally Posted by VTuner View Post
    I can reproduce the fault here. Working on a fix.
  1. Update: Jul 04, 2014
    Last Post: July 8th, 2014, 09:56 AM
  2. Known issues with Jun 21, 2014 release of the EFILive software and firmware.
    Last Post: July 3rd, 2014, 11:12 AM
  3. Known issues with Nov 07 2013 release of the EFILive software and firmware.
    Last Post: June 14th, 2014, 10:53 AM
  4. Software issues with build 99 pre release...
    By LBZoom in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 18th, 2010, 04:25 AM
  5. EFILive 7.3 pre-release software is now available
    By Blacky in forum General (Petrol, Gas, Ethanol)
    Last Post: August 18th, 2005, 11:51 PM
