Originally Posted by picnic_george Map sensor scaling was causing 1 bank to pull a ton of fuel but the other bank was not pulling an unreasonable amount? I still think he has not solved the problem.
Originally Posted by joecar Post new log file. Is your FPR MAP-referenced or un-referenced...? its on a log from the intake.
Originally Posted by wickedcummins its on a log from the intake. So your FPR has a reference hose that sees manifold pressure/vacuum...? If so, then your IFR table is wrong, it should be flat, same value all across.
ok I set to 135.5 across the board and will test it tonight. Thanks Joe
gjjjj.efi here is a test hit
Forum Rules
