How do you get the correct TPS voltage to 0.5 to 0.6.Mine is 1.7 volts at start up.Is it suppose to be 0.5 all the time,even on cold start up? Do you oblong the holes in the TPS sensor that hold it to the TB?..............Paul
The TPS on the GEN3 motor is self adjusting. It is not like the L98/LT1 days where .5 volts represented idle. It will never read zero so don't worry about it. As long as the FS reads 99%+ the PCM will see WOT and I would think the lowest number is closed throttle.
www.redline-motorsports.net
1-954-703-5560
2006 ZO6 895/866 with APS TT
2011 HTR-850R Camaro
Thanks Redline,I forgot to mention its a 97 C5.Your not to far from me,I'm about 40mins south of you.
Hi neighbor!Originally Posted by driver456
Let me know if you need assistance with dyno tuning or any other related GEN3 mods!
Howard
1-954-703-5560
OK,thank you ..................PaulOriginally Posted by Redline Motorsports
