Results 1 to 9 of 9
Thread: turbo whistle
    Sep 2013
    Default turbo whistle
    I have a 08. I wan't to make my turbo whistle as loud as it can.any one know how to do this.
    May 2014
    Disable computer control of the boost pressure during lightly loaded conditions
    Set VVT at or near 100% closed during lightly loaded conditions
    Enable computer control of the boost during loads greater than lightly loaded conditions. Computer control of boost will keep boost under control without changing so many tables.
    Others will have more help.
    Mar 2009
    Replace the intake with a free flowing unit, and do away with the resonator. They you can up the vein percentage, but you will be wasting power IMO.
    Sep 2013
    I figured it would hurt my power.I don't want that. I've read that putting on a metal intake would increase the whistle.
    May 2014
    Nearly closed turbo vanes do not produce the most efficient idle. The rumble idle uses the least amount of fuel. Rumble idle is opposite of hissing idle.
    Sep 2013
    That's when I want more whistle, when its at idle. So your saying to add more fuel at idle.
    2008, efi live, 5" exhaust, profab egr delete tube, up pipe, down pipe, air dog 165,cap , block .
    May 2014
    Engine will automatically add more fuel at idle. Closed turbo is a restriction of the exhaust.
    Closed turbo is used as an exhaust brake but it makes the sound you are interested in hearing.
    Sep 2013
    OK but I thought even at 100% closed the exhaust still had flow not to hurt anything. I will play around with it.
    Mar 2009
    Quote Originally Posted by lp14255 View Post
    The engine will use whatever amount of fuel it needs to idle, you can't change that(you can only change the pressure and timing of when the pulse occurs). Anything more than the factory 80-85% isn't going to do much except to block off the exhaust even furthur. Put in a cold air intake with a dry filter that does away with the intake resonator, that is going to do more than anything else to make you hear the turbo.
  1. t/h and turbo brake?
    By lp14255 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: March 24th, 2014, 09:00 AM
  2. turbo tune
    By vcls1 in forum Gen III V8 Specific
    Last Post: December 11th, 2012, 02:01 AM
  3. turbo tune
    By vcls1 in forum Gen IV V8 Specific
    Last Post: June 12th, 2012, 03:19 PM
  4. Closing turbo vanes for turbo braking?
    By Haulinbass02 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: May 14th, 2009, 12:12 PM
  5. twin turbo's
    By limited cv8r in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: July 15th, 2007, 03:22 AM
