Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: can efi live eliminate the shift adapts on the allison?
  1. #11
    Lifetime Member Max Power's Avatar
    Nov 2005
    Thanks for sharing. I will play with it when I get a chance.
    09 LMM Duramax
  2. #12
    Default that works
    Quote Originally Posted by Dieselholic
    The most effective tables I've found are the Shift timing tables, in the parameters field I reduced all the "base desired shift completion time" tables by a small percentage. Also in the "Desired X->X Shift Time Throttle Adjust" tables for each specific upshift, Normal & Tow/Haul, I also reduced the table values by a small amount (not percentages) in the 75% tps ranges & above. I left all pressures untouched for now, oh yea, 1 last thing, I Disabled the Upshift Adaptive Learn Tables, but left the Kickdown Adaptive Learn Enable "Enabled". Just be sure to Preset the TAP cell values after reflash, but they should have been Preset when the flash was performed. Keep in mind that small changes are all that is needed, they respond very noticably to slight changes.
    I had a chance to play a little more, I found once I got close to where I wanted the shift timing (feel) & re-enabled the Upshift Adaptive Learn Tables, there was little to no change in the way it shifted, I would prefer to leave the adaptives on, as it aids in shift quality consistency once you have it tuned correctly, particularily as the transmission wears.
    Todd.
    these are great tips thanks i am just starting to play with the tranny
    2017 Trailblazer 2.5L Dmax
    07 LBZ rc lb EFI - Sold
    05 lly cc lb, EFI 80hp tune-Sold
    01 lb7 rc lb EFI & Road Runner,1000+hp -Sold
    Duramax power
  1. adjusting allison shift
    By dezzi in forum Allison 5 & 6 Speed
    Last Post: February 1st, 2010, 10:29 AM
  2. Service fast learn adapts
    By PSWired in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: April 29th, 2009, 12:50 PM
  3. Adjusting Allison Shift Times
    By Sparky8370 in forum Allison 5 & 6 Speed
    Last Post: June 30th, 2008, 09:24 AM
  4. PIDs for allison shift times?
    By turbo lcc in forum Allison 5 & 6 Speed
    Last Post: July 24th, 2007, 11:45 AM
  5. Eliminate TCM
    By thetallengineer in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: March 29th, 2007, 01:27 AM
