Results 1 to 5 of 5
Thread: DIY Knock Headset
    Mar 2012
    Default DIY Knock Headset
    Hi everyone.
    Has anyone had a go at building their own knock headset before?
    I have read posts in other forums such as this:
    http://www.k20a.org/forum/showthread.php?t=27258
    And using this concept:
    http://www.efiexpress.com/catalog/ar...?articles_id=4
    I have gone ahead and bought some stuff tonight.
    http://pages.ebay.com/link/?nav=item...d=171352933828
    http://pages.ebay.com/link/?nav=item...d=171083334052
    http://pages.ebay.com/link/?nav=item...d=390843712877
    I will be listening for noises like this! http://youtu.be/GGJZ6kKzLusi
    Has anyone else had a go at doing this and what luck did you have?
    Ill post my results when I finish it in a couple weeks. If it works its going to be great at eliminating real or false knock!
    Mark
    Cool (pretty clever using laptop's mic input)
    I've been using parts hacked from a Steelman Chassis Ear I picked up from a garage sale.
    Mar 2012
    What would be super helpful would be sound recording software that uses the same time stamp as the laptop time. Same as how EFILIVE does so then you could look back at logs and soumd clips to identify where exactly the knock is present.
    Nov 2014
    interessting. so what became out of it. does it work, do you use it? i always wanted to connect the knock sensor to the stereo, making use of the equalizer. btw, whats the formula again to calculate the knock frequency?
    To see the knock sensor frequency, you have to record a knock event on an oscilloscope which has FFT ability.
  1. DIY cable problems
    By aliman in forum EFILive V4
    Last Post: November 28th, 2010, 10:13 AM
  2. Knock Retard GM.KNKRET vs Retard Due to Knock GM.KR
    By Gelf VXR in forum General (Petrol, Gas, Ethanol)
    Last Post: March 9th, 2008, 04:18 AM
  3. Custom/DIY calibration definition file?
    By jimter in forum General (Diesel)
    Last Post: October 10th, 2007, 09:25 AM
  4. Knock after COS #3 install, but never had knock before
    By CRU SS N in forum Custom Operating Systems
    Last Post: June 15th, 2007, 10:07 PM
  5. TTi Stage 1 Question/DIY Tuning
    By lplott in forum General (Petrol, Gas, Ethanol)
    Last Post: August 19th, 2005, 03:00 AM
