Where you have "iff({1}, ...)" remove the br aces from the 1 so it is simply "iff(1, ...)".
No worries.
He's ok, he assumed you knew how to edit CLC's (which is a fair assumption).
ok i think i got it
sorry if i offended any body...
so the displacement issue... i have 2 trucks one is a 5.3 and one is a 6.0...
do i just change displacement per cylinder in the brackets in the calc_pids.txt every time ??
or do i use whole displacement of all 8 cylinders in litres or cubic centimeters ???
where can i find in depth info on editing clc's ???
also when i updated there was a dropdown list that let me select displacement cant remember how to get back there or if it was a perminant change
No... use VE units g*K/kPa... using these means you don't need displacement.
See here: Collecting-links-to-scattered-material->post#21where can i find in depth info on editing clc's ???
If you use g*K/kPa you can ignore displacement.also when i updated there was a dropdown list that let me select displacement cant remember how to get back there or if it was a perminant change
ok so heres a few pics of my maf adjustmentsthe first pic is after i pasted and multiply
second pic add average % of LTFTs 9000hz - 12000
ok so the last pic is it all smothed the paste and multiply dosent work ???
is this because the rpm in scan tool and rpm in tune tool???
now to mess with idol cuz it wants to stall...
and reset fuel trims...
does this look ok?
