The drop down of the MAF table from 9000 Hz to 12000 Hz has to be manually applied to below 9000 Hz, which the third pic looks like you have done... if the MAF continues to be a smooth monotonically increasing 4th order polynomial curve, then it is correct.
When you get that error, it means you copied without labels.
