Results 1 to 10 of 12
Thread: couple of questions
    Feb 2014
    Default couple of questions
    Is anyone blending , like row or column while emmulating you ve tables ?
    I saw a post about linear blending after emmulating ,but I cant seem to find the post on how and when to use it.
    Iknow its imossible to hit every cell , my new project is a 2001 s10 4.3 stock engine with 36lb injectors , emmulating at idle ,my ve table almost doubles , should i save some time and raise it myself and get it closer so im not a week into it , lol
    I never found a real list of what tables the rr can do ?
    thanks guys
    Joecar see ya soon bro
    Jim
    Hi Jim,
    Usually the tables are close enough that blending/smoothing is minor.
    If your VE table is so far off, are you sure your IFR table is correct...?
    RR can do all the tables that you can see in the EFILive V7 tunetool... you just have to figure out what the feedback pid should be.
    Feb 2014
    ifr is def correct joe , nice to hear from you again the injectors are almost double in size on the stock engine
    jim
    Feb 2014
    new problem , i just updated all pc,s with new software and patches and apparantly or maybe they kicked out my drivers and none I try work now , all i see is a window that says usb device not recognized will all pc,s and installing older and newer drivers and doing the flcean inbetween ARRRRRRRRRRRgh , very frustrating , finally learning the RR now its .
    Start->All Programs->EFILive->V8->EFILive USB Manager
    and try the oldest driver.
    Feb 2014
    says no support on on windows 8 , im stumped and maybe done ,my
    maybe over , no time for this petty stuff , worked fine before , might be up for sale if i cant fix it without spending days on it
    thanks for the reply joe
    Feb 2014
    ive done what you asked and my computer cant even see the scanner in any computer and still have the same problems above with rR usb device not recognized
    Feb 2014
    which old driver to install for efi , then what about THe RR
    Are you logged in as Admin...?
    Also, if your PC supports USB3 ports, go into the BIOS/boot setup menu and reconfigure them as USB2.
  1. Couple of LMM Questions
    By Cougar281 in forum Diesel
    Last Post: January 26th, 2009, 06:42 PM
  2. couple of questions ...
    By drdarthinvader in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: December 4th, 2008, 02:33 AM
  3. Couple little questions
    By samdweezel05 in forum Duramax LB7
    Last Post: November 22nd, 2008, 05:25 AM
  4. couple of questions.....
    By WHYTRYZ06 in forum Custom Operating Systems
    Last Post: March 16th, 2008, 05:37 AM
  5. couple of questions from a beginer
    By HINDZY in forum Gen III V8 Specific
    Last Post: August 6th, 2007, 07:56 PM
