Results 1 to 4 of 4
Thread: What to log for stalling issue
    Jun 2009
    Default What to log for stalling issue
    Randomly when I come to a stop my car will stall (not all the time though). Not sure what is causing it, seems to be only happen when I have been driving for quit some time. I'm wondering what I should be logging to try and catch what is causing the issue?
    Seems like the problem was much worse before I added additional air flow in B4307 and put B4309 to 0 at low rpm and low mph cells. It acted as if coasting to a stop it switched from the B4309 to B4307 at 0 mph, and the engine would want to die because suddenly it had less air flow. I figure this way it won't suddenly be changing airflow by having a high value in b4309 then nothing once it hits 0 mph and running only off b4307.
    Should I add more while in gear? I'm basically at 50% more than stock, which seems like a lot. I have put really high values in there before and it makes the car want to idle really high. Engine is stock other than a cam, which was in it when i got it. then I built a turbo kit and run it on e85.
    Hmmm, sounds like Throttle Follower and/or Throttle Cracker, but I'm not sure...
    post some log/tune files.
    Jun 2009
    Here is the tune. I will try and get a good log of the issue tomorrow to post up.
    Jun 2009
    Finally got a new log with it happening. Here is the screen shot. At the very end of the log i was coasting to a stop. The engine surges a little bit then dies. Any ideas on why? This is the problem i'm talking about. Right before this i coasted to a stop and it didn't do this, 15 seconds later and it stalls out.
    Attached is screen shot, latest tune, and log file.
    I have putt the throttle cracker back to stock. The throttle follower tables are setup like the idle tuning tutorial, and I am thinking about putting them all back to stock to see what happens.
  1. Stalling in reverse
    By dsltnr in forum Cummins 6.7L
    Last Post: May 19th, 2013, 07:43 AM
  2. Dual fueler SURGE AT WOT issue ECM overcorrecting? PID LOOP?..Log Inside
    By Dmaxink in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: June 26th, 2012, 09:18 AM
  3. Stalling issue... almost everywhere
    By lastcall190 in forum Gen III V8 Specific
    Last Post: November 21st, 2008, 08:33 AM
  4. Intermittent Stalling...
    By ArKay99 in forum General (Petrol, Gas, Ethanol)
    Last Post: September 27th, 2007, 01:59 PM
  5. Can't increase timing while brake stalling (tune and log attached)
    By thunder550 in forum Gen III V8 Specific
    Last Post: January 18th, 2007, 04:44 AM
