Results 1 to 8 of 8
Thread: Timing calculator?
    Junior Member longcummins's Avatar
    Feb 2013
    Default Timing calculator?
    Can someone explain or give some advice as to what to read, where to get info on how to understand the how and what ? I am all ears and willing to read whatever it takes to help understand it. Thanks
    Last edited by joecar; August 6th, 2014 at 10:43 AM. Reason: corrected spelling of title
    Feb 2013
    Thanks for the support not.
    Member Motorzane's Avatar
    Jun 2011
    You will get a lot better response on this forum if you use the search function first. Try this out and see if this helps. https://forum.efilive.com/showthread.php?t=18117
    Member mpdtune's Avatar
    Jul 2013
    Timing calculator uses duration and fuel pressure to determine how long it will take to inject the fuel at a given rpm. The percentage is used to determine how much of the fuel is injected before TDC.
    Feb 2013
    Motorzane have to say this I have searched for this in the 6.7 forum but I honestly never though about the 5.9 section until your post thanks for your reply. mpdtune thanks also for you help in my trying to learn this and not destroy my truck in the process.
    467.7 FMW Stainless Diesel
    Jul 2013
    A good starter tune is to make sure you're commanding full fueling from the main injection duration table. Look at the x and y axis for the table and go to the tables they reference. Bump the upper half or so of main injection by 20%. Go to the timing table and use the calculator to set timing 50% before TDC. If you have the emissions removed, go ahead and turn off the post injection by zeroing those tables.
    Feb 2013
    I have post set to zeros and I am running with out any codes so I am good there. Thanks for your reply. I am finding some useful info over on the 5.9 section that should help some also.
    Jun 2011
    Here is some good info to help you get started. The price is not bad for the information and knowledge you will learn. http://www.starlitediesel.com/EFILiv...N-ADVANCED.htm
  1. timming
    By chance cobb in forum Cummins 5.9L
    Last Post: October 14th, 2012, 06:50 AM
  2. 40 Degrees max timming, i want more
    By fezz57 in forum Gen III V8 Specific
    Last Post: November 5th, 2011, 08:36 PM
  3. Shift timming
    By bdr2008 in forum Allison 5 & 6 Speed
    Last Post: February 17th, 2009, 02:19 AM
  4. Duramax timming
    By Rambo in forum Duramax LB7
    Last Post: April 7th, 2007, 08:23 PM
  5. retard timming for N.O.S. help please
    By RandyWS6 in forum General (Petrol, Gas, Ethanol)
    Last Post: March 9th, 2005, 06:52 AM
