Currently known issues and possible workarounds for the July 12, 2014 release of the EFILive V7.5.7.261, V8.2.2.256 software and the V2.07.63 FlashScan and AutoCal firmware.
Issue 1:
Workaround:
None. It is a restriction of the *.efi (V7.5 log file format). That restriction will be removed and the TCM PIDs will display their true origin once the V8 scan tool software is available.
Issue 2:
When black box flashing T43, T76 and A50 controllers that had previously been VIN licensed, the VIN license is no longer recognized.
Workaround:
Use V8 pass-thru flashing which correctly identifies the VIN license
Or download and install the attached firmware using EFILive Explorer. Unzip the firmware files into a temporary folder. Do not overwrite the existing firmware files, or the next time you perform a "Check for Updates" the update will fail and you will need to perform a full install instead.
UPDATE: the original July 21 firmware patch has been updated, please download and install the July 22 patch.
Will be fixed in the next update.
Issue 3:
Setting a controller serial number security restriction for AL5 tune files will always fail to flash, returning error $0530.
Workaround:
None. Will be fixed in the next update.
Issue 4:
After opening a scan file in V8 and then displaying file info (Ctrl+I), then closing the window, then re-opening the Scan window again, displaying file info again (Ctrl+I) will fail with "Access violation".
Workaround:
Issue 5:
After changing comments in a tune file using the V8 software, then closing the window, you are not prompted to save the changes. The changes are discarded without warning.
Workaround:
Save the tune file using the [Save] button before closing the window.
Issue 6:
Black Box Logging is not supported for Cummins controllers, except for CMB EDA (Enhanced Data Acquisition) PID selections.
Workaround:
Use the V7 pass-thru logging to log CMB (non EDA selections) and CMC controllers.
EDA PIDs are expected to be available for CMC in the next update.
Issue 7:
The V7 tune tool does not release the connection to FlashScan after performing the "Save for Remote Flashing" option. That means neither the V8 software nor the V7 Scan Tool can connect to FlashScan until the V7 Tune Tool software is shutdown.
Workaround:
To allow V8 (or the V7 Scan Tool) to connect to FlashScan either:
Close the V7 software
or
Open the Flash->Show PCM Info window, click the [Get Info] button, then close the window. That effectively closes the connection to FlashScan.
Issue 8:
The link PIDs for E38 calibration B5108 are transposed.
Workaround:
Edit the file \Program Files\EFILive\V7.5\Configuration\E38_Link.ini and change the entry for B5108 to this:
;IAT vs RPM Spark Multiplier
B5108.ROW=SAE.RPM
B5108.COL=SAE.IAT
Issue 9:
The PID EOPS (Engine Oil Pressure Sensor voltage) is not displayed when loading log files into the V8 Scan Tool.
Workaround:
Use a hex editor (not a text editor) to edit the *.efi log file and change the PID name: GM.EOPS to XX.EOPS.
WARNING: Changing the PID name will prevent V7 from loading that PID.
