I just updated to the July 19 public release and found a scaling glitch in LMM DSP5 tables. In the DSP section of the tune file, the RPM row for the fuel pressure tables is messed up. Across the top of all of the DSP fuel pressure tables of the tune file it is scaled differently from the base file. The numbers all look correct if you substitute the normal numbers in for the RPM's instead of what is there. Just threw me for a loop when I seen the table go 0, 100, 200 and so on instead of 200, 400, 600 and so on. I got a couple of screen shots to show you what I'm talking about. Look at the RPM row across the top and the scaling. I checked it on the 2 different OS's I have for LMM's, and the scaling error was in both of them. I also ran into an issue running scripts. If I keep the EFILIVE V7 window open while running the script, it kept going in a loop over and over. I had to go in and shut it down via the task manager as nothing else worked. I opened my browser and went online while letting the script run in the background, and it worked. Another thing that was strange was while running the script when I had the window up, once it got to the part to modify DTC's, the script window disappeared under the tune windows, and that is when it went wonky. Tried it again and the same thing. That's when I opened my browser and let it run in the background and it worked.
