Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
Thread: Known issues with Jul 19, 2014 release of the EFILive software and firmware.
  1. #21
    Mar 2009
    Very strange because the last logged change was calz v7.28, 2012-Aug-14 where we just added some LMM boost error tables (B2255 - B2257). What is the .calz file version/date in build 211 that shows correctly?
    Not to sure as I have updated all of my computers to the latest build software. I still have the downloads from them saved, but not sure how to find what you need from that. All it shows is EFILiveV7.5.7.211_Setup and when I highlight it it says file version 9.0.4.0 .
  2. #22
    Nov 2005
    Quote Originally Posted by THEFERMANATOR View Post
    211 would need to be reinstalled, then navigate via Program files to look at the date of the calibration files.
    I'll look around the office and see if I can find the installation and check out the details Ross requires.
    Cheers
    Cindy
  3. #23
    Nov 2005
    We've reinstalled build 211. The calibration files installed in version 211 for the 2 OS's you quote are the same as the calibration files in the current version. The last change made on those particular OS's that were released publicly were made in March 2010.
    If you're certain they are different, then you'll need to open your tune in V7 software, and under the calibration tab note down the version number and date. You will then need to uninstall V7 and reinstall build 211 and repeat those steps.
    If you have a difference between versions and dates listed in both software builds please let us know.
    Cheers
    Cindy
  4. #24
    Member jay p's Avatar
    Dec 2005
ID:	17447Click image for larger version.
    I uninstalled 7.5 and installed v211. I still get the same thing. The DSP fuel press is scaled wrong and the base OS is correct.
    Both the DSP5 and base OS calz files were created on 3-25-2010 (same date as the ones for v262).
    Jay
    2019 Sierra 6.2l
    2017 2500HD L5P
    2010 2500HD LMM (sold)
    2005 Harley Ultra Classic
  5. #25
    Lifetime Member Chuck CoW's Avatar
    Feb 2006
    Ross... Was playing with a 2015 LML the other day. Found myself copying segments from the alt cal to the main cal (from stock tune to my modified tune) to
    find a bug that was messing with me. I was trying one segment at a time to isolate the problem and then when I narrowed it down to the segment I thought
    was at fault, I realized for instance that not all of the speedo related calz were actually in the speedo segment. Thought I was crazy, but (hopefully not) it appeared
    that some cals you would assume belonged in the speedo segment were mixed in other segments.
    I wasn't sure if the compare/update feature was not moving them over correctly or if possibly those few cals were actually located elsewhere.
    Chuck CoW
    CoW BOOSTER! Electronic Throttle Enhancement.
    - CLICK HERE NOW FOR MORE INFORMATION! -
    VARARAM, EDELBROCK, AMERICAN RACING HEADERS, BAER BRAKES, BORLA, EFI Live, Magnuson,
    COMP Cams, PROCHARGER, PRO TORQUE, PHADT Racing, INNOVATORS WEST, and more.
  6. #26
    Dec 2005
    Ross,
    Here is a strange one for sure...........LMM C5500 file, set to display all data in imperial it shows PSI whilst any other LMM I open displays in MPA.
    Tony
    Also the tables B2256 and B2257 seem to be missing in the regular LMM Cals but this C5500 shows them in the Boost Folder
Name:	LMM C5500 Fuel Pressure Maps.JPG
ID:	17473   Click image for larger version.
Name:	LMM B2256 Table.JPG
    www.mscservices.net
  7. #27
    Quote Originally Posted by GMC-2002-Dmax View Post
    Ross,
    I have not tried this with LMM files: have you tried to configure the units for that table by going Edit->Configure Display Units...?
  8. #28
    Dec 2005
    Yes, as soon as I open a tune file it gets configured to display all imperial units and is resaved.
    Tony
    www.mscservices.net
  1. Known issues with Jul 12, 2014 release of the EFILive software and firmware.
    Last Post: July 18th, 2014, 03:32 PM
  2. Known issues with Jul 07, 2014 release of the EFILive software and firmware.
    Last Post: July 10th, 2014, 10:12 AM
  3. Update: Jul 04, 2014
    Last Post: July 8th, 2014, 09:56 AM
  4. Known issues with Jun 21, 2014 release of the EFILive software and firmware.
    Last Post: July 3rd, 2014, 11:12 AM
  5. Known issues with Nov 07 2013 release of the EFILive software and firmware.
    Last Post: June 14th, 2014, 10:53 AM
