Page 5 of 5 FirstFirst ... 345
Results 41 to 42 of 42
Thread: Update: Jul 19, 2014
  1. #41
    Sep 2010
    Hi Guys, on about 10th August I downloaded (from the website) the latest version 7.5 and 8 and installed it in Compaq Presario CQ56
    It all seemed to work ok on a LS1b cable throttle
    Then I did a LS1b fbw VZ 5.7L Commodore, and no matter what i did I could not lean it out
    I tried VE's, PE, AFR, and Injector rate
    the cruise fuel was pretty good, but on dyno it was running 12 to 1 AFR, and no matter what I did could not change it
    I sucked calibration out, and compared, and it all seemed ok
    The car had been tuned before and maybe by HP...... so not sure if there was a conflict there.
    Then later I had to touch up a E38 tune from the week before with my old laptop, and this is where it got messy.
    I couldnt get my Scan tool dash page to work properly
    The E38 dash only had 6 panels, and the PID list only showed about 130 pids, none of which were the ones I wanted.
    The spark was reading -45 degrees and MAP was 17kpa, which is totally wrong.
    I wasnt able to change or correct anything
    Any suggestions????
    I am in a bind and cant use my old laptop, now dongle has been updated....
    Any help much appreciated
  2. #42
    Not sure if this will help you or not, but there is an option in the V7 menu: Dashboard->Recall installation defaults->Reset "Default LS2" dashboards.
    That option will reset your dashboard to how it was when the software was installed.
  1. Known issues with Jul 19, 2014 release of the EFILive software and firmware.
    Last Post: September 12th, 2014, 12:12 PM
  2. Update: Jul 12, 2014
    Last Post: July 13th, 2014, 07:51 PM
  3. Known issues with Jul 07, 2014 release of the EFILive software and firmware.
    Last Post: July 10th, 2014, 10:12 AM
  4. Update: Jul 04, 2014
    Last Post: July 8th, 2014, 09:56 AM
  5. Update: Jul 07, 2014
    Last Post: July 8th, 2014, 09:55 AM
