Results 1 to 3 of 3
Thread: Oxygen sensor placement with H-Pipe?
    Lifetime Member samh_08's Avatar
    Oct 2008
    Default Oxygen sensor placement with H-Pipe?
    How close to a H-Pipe can I be with my oxygen sensors? Currently I dont have any cats and my O2 sensors are mounted 6" past the 4 pipe header collector.
    I believe H-Pipes need to be fairly close to the collectors to work properly, but I dont want to mess with my tuning. I would think having it too close would skew the readings somehow. Anyone with first hand experience?
    Also, I have true dual 2.5" exhaust right now. How much smaller does one make the h-pipe?
    Jul 2005
    Quote Originally Posted by samh_08 View Post
    Typically an H-pipe is 2/3's the diameter of the rest of the exhaust. You can get some decent low-mid rpm torque with an H-pipe.
    I read somewhere that you can take a crayon and with the exhaust hot, drag the crayon from your header collector towards the rear of the car. The point at which the wax crayon stops burning, is the point at which the H-pipe should be located. I have no personal experience with this.
    If your header collectors are 2 1/2" and your exhaust is the same diameter, the h-pipe serves as the termination point for the tuning effects of the collector, If you have a 3" collector and 2 1/2" the collector termination occurs where the 2 different diameters come together.
    peace
    Hog
    Oct 2006
    I would stay before the crossover of the H pipe, about like you are now.
    2006 Trailblazer
  1. Oxygen sensor install tips
    By Wheelz in forum Lounge
    Last Post: December 14th, 2013, 07:32 PM
  2. Is there a parameter that specifies the position of the Oxygen sensor? E38
    By Highlander in forum E37, E38 & E67 PFI ECM's
    Last Post: October 1st, 2012, 10:50 AM
  3. How important is IAT sensor placement
    Last Post: May 13th, 2009, 12:16 PM
  4. Disabling post CAT oxygen sensor DTC? Possible?
    By andyfanshawe in forum Vortec V6/V8 Specific
    Last Post: April 29th, 2008, 03:33 AM
