Results 31 to 40 of 40
Thread: calculated pid not valid for NGK/NTK Air-Fuel Ratio Monitor
  1. #31
    Feb 2012
    What is the EXT.AD1 pid doing, Trackman?
    That will tell you if the V2 is reading the input and it's just a calc.pid thing.
  2. #32
    Jun 2014
    I don't know the answer to that. I assumed if it was on it was doing it's job.
  3. #33
    The scantool is freezing...? Are you able to post a screenshot...? Do you remember if the scantool was from a V7 build from this year...?
  4. #34
    Jun 2014
    The scantool is not freezing.The afr pid is just stuck on a random number.
    I believe the V7 build is from last fall. V7.5.7 build 282
    I just don't understand what has changed from the summer of 2014 when the pid worked perfectly to now.
  5. #35
    You need the latest software (EXT.ADx pids got broken and have been since fixed).
  6. #36
    Do you have a V2 or a V1...?
  7. #37
    Jun 2014
    I updated to the March 2016 public pre release.
    I have a V2.
    I look forward to testing.
  8. #38
    Jun 2014
    It seems to be working correctly now.
    I am guessing the update was all that was needed .
    Thanks again Joecar.
  9. #39
    Jun 2014
    I was comparing my older cal pid vs the new version. I noticed the low and high of currently used pid are slightly different. Would this have any affect on my afr readings on my V2? The monitor does read from 9(0.5v)-20(4.5v) which is the low and high settings of the older pid version.
Name:	calpid compare.png
  10. #40
    Low, High, Fmt:
    these are used to set the minimum tick mark, the maximum tick mark, and the number of digits after the decimal point when you add that pid to a chart or a gauge...
    i.e. they effect how the guage/chart looks, they do not effect the value range of the pid.
  1. Air/Fuel Ratio Adjustment
    By kylelavergne in forum Gen III V8 Specific
    Last Post: December 26th, 2013, 04:22 PM
  2. Air Fuel Ratio or Timing for Peak Power
    Last Post: September 23rd, 2009, 04:42 AM
  3. Air-Fuel Ratio Monitors
    By Sid447 in forum General (Petrol, Gas, Ethanol)
    Last Post: February 24th, 2009, 09:45 PM
  4. AFR Command Air Fuel Ratio
    By james01ss in forum Gen III V8 Specific
    Last Post: October 6th, 2008, 01:33 PM
  5. Air Fuel Ratio
    By batesyellow01 in forum Petrol / Gas
    Last Post: March 15th, 2007, 03:25 AM
