Results 21 to 30 of 40
Thread: calculated pid not valid for NGK/NTK Air-Fuel Ratio Monitor
  1. #21
    Post a screenshot of the PIDs tab (showing the pid CALC.NTK_AFX)...
  2. #22
    Jun 2014
    Did you select the pid EXT.AD1...?
    Did you select the pid CALC.NTK_AFX...?
    This is what I see:
    Attachment 19559
    Yes I did.
    Just as I was going to screen shot my pids I double checked to see the pid parameters and now its valid!
    I hope to test it later today.Click image for larger version.
  3. #23
    Jun 2014
    I tried it tonight and and stays on 11.1. I'm going to get a meter and double check voltage output of the afr monitor to confirm it's working.
  4. #24
    Quote Originally Posted by Trackman View Post
    On your charts, you will have to re-choose the correct pid into the chart...
    the correct pids now are CALC.NTK_AFX.LAM, CALC.NTK_AFX.EQR, CALC.NTK_AFX.AFR.
  5. #25
    Jun 2014
    I have confirmed aux output voltage from the afr monitor is working correctly. It reads 4.5v in free air and with the car running it was fluctuating between 1.8v-2.2v on my meter with an afr in the high 12s- low 13s.
    When I connect to the V2 I still don't get any correct data when any one of the CALC.NTK_AFX.LAM, CALC.NTK_AFX.EQR, CALC.NTK_AFX.AFR. That pid just freezes up on a log.Click image for larger version.
Name:	pid selection.png
ID:	19575Click image for larger version.
Name:	log screen shot.png
    I'm wondering if it will be easier to start over with a new calc. pid. I don't use and other analog inputs anyway.
  6. #26
    Post your log file and your calc_pids.txt file.
  7. #27
    Which V7 build version are you using (go Help->About)...?
  8. #28
    Jun 2014
    calc_pids.txt
    I am using the calc pids file you posted.
    Build 282Log_0002.efi
  9. #29
    Sorry, my apologies...
    I posted a bad calc_pids.txt in post #16 above (was missing closing quotes and duplicated CLC-00-003)...
    I have now corrected the calc_pids.txt and re-posted to post #16 above and here also.
    Note: please log SAE.LAMBDA and post the log file, I want to see what it does.
    Also, I think you should upgrade your V7 software to latest build (and if you have FSV2 then update V8 also, and FSV2 firmware also).
  10. #30
    Jun 2014
    I an grateful for you time. Thanks for helping.
    No change. The pid is froze
    I checked for updates and firmware updates and it says I have the latest.
    Sorry I can't seem to find the SAE.LAMBDA
  1. Air/Fuel Ratio Adjustment
    By kylelavergne in forum Gen III V8 Specific
    Last Post: December 26th, 2013, 03:22 PM
  2. Air Fuel Ratio or Timing for Peak Power
    Last Post: September 23rd, 2009, 03:42 AM
  3. Air-Fuel Ratio Monitors
    By Sid447 in forum General (Petrol, Gas, Ethanol)
    Last Post: February 24th, 2009, 08:45 PM
  4. AFR Command Air Fuel Ratio
    By james01ss in forum Gen III V8 Specific
    Last Post: October 6th, 2008, 12:33 PM
  5. Air Fuel Ratio
    By batesyellow01 in forum Petrol / Gas
    Last Post: March 15th, 2007, 02:25 AM
