Results 1 to 6 of 6
Thread: 2006 Corvette stock tune, not so stock?
    Aug 2014
    Default 2006 Corvette stock tune, not so stock?
    New to EFILive, some Ford experience form many years ago.
    I have played around with the V2 and software and downloaded from the car to look around. Car was purchased used, so it may have been edited?
    2006 Corvette base. MN6. LS2. No mods. OS 12605732
    There is a date listed in the .cal file, but it makes no sense as the car was in my possession at the time.
    Looks like the CAGS is disabled, other RPM limit changes, and who knows what else may be changed?? Car runs great, I just want to have a clean baseline.
    Can someone send me a stock file to compare?
    Thanks!!
    What .cal file are you referring to? EFILive doesnt have use .cal anymore, that change was made back in ~2011 or so. The extension .calz stor Calibration information.
    The .calz files have a modified date of whenever EFILive released an update to the Calibration files (.calz). .tun files might have the date they were read, but I havent used them in a few years now. .ctz files have metadata to tell you when they were read.
    Check TuneFileDepot.com for stock tunes.
    Aug 2014
    You are correct, it is .calz I guess I was just being lazy.
    I checked TuneFileDepot and the closest I see is a Z06 file.
    No prob, I dont have a stock 06 Vette file. Hopefully someone will chime in with one.
    Apr 2007
    Do a search here and you may find a file. You can also compare a 05 or 07 file as well.
    Make sure to match the operating system and trans as well. Disregard the date in the file.
    Aug 2014
    Just an update.. And a thank you for the info above!
    Car has OS 12605732, some minor changes in it. I have available if anyone needs it.
    I also purchased a spare ECM which supposedly has the most recent GM flash in it. OS 12614682 also available if needed.
    2006 C6 LS2 manual. E38.
    Wideband is in.. Will be gathering log data next weekend.
  1. Corvette VS. Trans Am stock tune
    By dieselz28 in forum Gen III V8 Specific
    Last Post: March 5th, 2011, 02:34 AM
  2. Need Stock Tune for 2006 C6 Z06
    By E.A. in forum E37, E38 & E67 PFI ECM's
    Last Post: September 24th, 2008, 02:41 AM
  3. 2006 Vette MN6 stock tune?
    By Bruce Melton in forum General (Petrol, Gas, Ethanol)
    Last Post: August 26th, 2008, 12:28 PM
  4. Need a stock 99 Corvette tune please.
    By horsehaulin in forum Gen III V8 Specific
    Last Post: May 9th, 2008, 04:24 PM
  5. I wont stock PCM for corvette C6 2006
    By hassan in forum Gen III V8 Specific
    Last Post: March 26th, 2007, 04:07 AM
