Results 1 to 10 of 16
Thread: Checksum error code $06FF with L92 PCM
    Lifetime Member 67SS509's Avatar
    Dec 2005
    Default Checksum error code $06FF with L92 PCM
    Tried to cal flash a modified tune into a 2014 Chevy truck with the 6.2 engine and OS #12663390. At the end of the flash got a "Script Exited with Code $06FF-Checksum Failure" . Engine would not crank or run. I then flashed the stock file back into it and it cranked and appears to be fine. Any ideas on what I need to do different or change?
    2002 Chevy truck, SCSB 2WD, Stroked LS3 w/Big Mutha Thumper cam
    2002SS Camaro LS7/427 with stock suspension setup
    2012 Chevy truck, SCSB 2WD, Magnaflow exhaust + K&N
    Any chance this ECM has had another programmer on it before?
    I'm seeing same "Checksum Failure" on a 2013 E38 file that I sent to Paul... my customer claims he flash with GM TIS...
    this happens only when flashing with V8 or V2 BBF.
    Flashes with no errors when using V7.
    If anyone wants to post tunes I can test them here.
    Dec 2005
    It was a tune that was copied from the PCM when it had a handheld programmer installed, changes were made to it and I tried to flash it in. What I finally got to work was compare the tune to the stock file, just copied the changes and it worked.
    Dec 2005
    I will post the tune tomorrow that would not work and let you take a look at it.
    I'll dig thru my emails...
    Quote Originally Posted by 67SS509 View Post
    That is the problem then, they alter the data in order to disguise the CVN changing on a modified tune, unfortunately EFILive thinks there is a checksum error because of this and the flash fails. I can fix it for you when you post the tune up.
    Lifetime Member Doc's Avatar
    Oct 2005
    Had this exact problem today. Please help.
    www.efialchemy.com
    www.greatamericancarwar.com
    Oh no, whoever it is they are doing it to E92's now! Your fixed file is attached.
  1. T43 TCM code $06FF: checksum failure
    By 400ss in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: August 15th, 2014, 10:26 AM
  2. $06ff error on E38
    By Y BE AVG in forum AutoCal
    Last Post: November 5th, 2013, 11:31 AM
  3. Autocal Error $06FF
    By Mike@Vengeance in forum AutoCal
    Last Post: July 30th, 2013, 01:49 AM
  4. Replies: 2
    Last Post: July 17th, 2012, 04:27 PM
  5. Checksum code
    By mstordahl in forum Cummins 5.9L
    Last Post: March 2nd, 2012, 04:43 PM
