Thread: Problems with my Dash readings?
    Apr 2006
    Default Problems with my Dash readings?
    Hello,
    I've been having problems with my Dash Board readings not giving me any info. When I launch V6 and start the connection the program see's my car and starts the link up then it came back a said "Unregistered Interface Found - would you like to enter your registration details now?". I type yes and it brings up all my info and I've verified it's all correct. When I go to the console window it said "Error: Unregistered interface, some features have been disabled". But in the mean time it lets me check my trouble codes and preform diagnostic's on the car. Can you help me troubleshoot this issues anyone?
    Thanks for your help!!!
    Jeremy B
    New Member Johninar's Avatar
    Jun 2005
    I have the same problem. I'm sure its with the way I'm entering the registration data. Anyone have a suggestion? I enter the 12 digit serial number, my key and date on the form. what else can I check?
    Sep 2003
    It's been a long time since I used V6, but most problems usually have the wrong date. Make sure you put the right YEAR in.
    Hope that helps.
    Jun 2005
    actually I am using version 7 because this new laptop assigns com12 for the AutoTap. I tried version 6 and it only goes to 9.
    Sep 2003
    Quote Originally Posted by Ninety8C5
    Hope that helps.
    This applies to V7 as well.
    Jun 2005
    I found out I need a new Key for ver 7. I sent a note are sending me a new Key. Thanks for the help. It looks like I'm close to resolving this.
    John
  1. Lc1 wrong readings.
    By tor1965 in forum General
    Last Post: May 4th, 2010, 09:47 AM
  2. What are your MAP readings?
    By TFZ_Z06 in forum Gen III V8 Specific
    Last Post: April 19th, 2010, 07:48 PM
  3. Problems with virtual dash
    By sixltrbtr in forum General
    Last Post: August 14th, 2009, 05:07 AM
  4. MAP Readings in a 5.3 Vortec
    By RacerChris in forum Gen III V8 Specific
    Last Post: February 26th, 2009, 01:18 AM
  5. AFR readings low through EFI
    By Chalky in forum General
    Last Post: May 18th, 2006, 02:24 PM
