Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Eops
    Quote Originally Posted by CR500 View Post
    Trying to log EOPS. Sent the PID to EFI, connect it to car, start logging and I can see EOPS varying like it should. Save file, shut down, connect to computer, and .... no EOPS?
    Any ideas?
    Using LS1B_A for a 2000 LS1 Corvette.
    EFI V8.2.2.258
    Firmware 2.07.64
    Boot 2.07.07
    Thanks!
    After investigating this issue, it is now a confirmed bug. GM.EOPS will not show up in the V8 scan tool. It will be fixed in the next update.
    The workaround is to hex-edit the *.efi log file and change the PID name GM.EOPS to XX.EOPS. That will force the V8 software to not try to (incorrectly) rename the PID to GM.EOP which is not a supported PID in V8.
    I've attached a fixed version of your log file.
    Jun 2014
    Whew, I wasn't doing anything wrong.
    Thanks!
    Thanks!
    No, I've got the monopoly on that :(
  1. Converting EOPS
    By Ninety8C5 in forum Do you want to be a Beta Tester?
    Last Post: May 20th, 2009, 09:45 AM
