Results 1 to 10 of 13
Thread: Eops
    Jun 2014
    Default Eops
    Trying to log EOPS. Sent the PID to EFI, connect it to car, start logging and I can see EOPS varying like it should. Save file, shut down, connect to computer, and .... no EOPS?
    Any ideas?
    Using LS1B_A for a 2000 LS1 Corvette.
    EFI V8.2.2.258
    Firmware 2.07.64
    Boot 2.07.07
    Thanks!
    Post log file.
    Jun 2014
    I tried EFI 7.5 and it can see EOPS!
    Am I doing something wrong with V8 or is another thing thats not quite ready?
    You have to select the pid CALC.EOPS and then save the log (no need to re-log).
    Jun 2014
    So I go into V8. Select Scan. Open log file, and can't find CALC.EOPS under available PID's.
    Actually, why would I need the calc pid (even though I can't find it)? I'm not trying to calculate the pressure, I can't even view the voltage (in V8).
    I can view the voltage (EOPS) and calculate the pressure in V7.5.
    Jun 2014
    No one ........
    Guess I'll bounce it to the support side.
    Sorry, my internet connection has been down for a couple of days...
    Calc pids are added in later when viewing the log file.
    So can you view EOPS pressure in the V7 scantool...?
    So in V8 and V2 BBL you can't see the EOPS voltage pid, is this the crux of the issue...?
    Jun 2014
    Log file was acquired via BBX.
    EOPS Voltage can be seen on the V2 while BBX recording.
    EOPS Voltage displays fine in V7.
    Can't see EOPS voltage pid in V8.
    Ok, I pm'd Paul, he said he's looking at it.
    Jun 2014
    Appreciate it!
  1. Converting EOPS
    By Ninety8C5 in forum Do you want to be a Beta Tester?
    Last Post: May 20th, 2009, 09:45 AM
