Results 1 to 10 of 14
Thread: Trying Calc.VET sets P0101 - did I do something wrong or is my MAF bad?
    Junior Member mys10v8's Avatar
    Sep 2009
    Default Trying Calc.VET sets P0101 - did I do something wrong or is my MAF bad?
    I am trying Calc.VET after running with an AutoVE tuned OLSD setup for a while - MAF has been unplugged for ~2 years (but not many miles - < 5000).
    First, just to be sure wo2 was still functioning and VE was close, I ran a couple logs with the AutoVE settings and got mostly .99-1.01 in BEN map so I think that's still working. Tune and log are attached.
    Next, I created tune file for logging Calc.VET (without CL/LTFT) from the above, and logged (both also attached). The MIL came on somewhere around time 09:30:40. I pulled over and looked at DTCs. It set a P0101. MAF frequency seems normal? (except near end of log when it's zero - I turned off ignition while still logging). Is that also why the DTCs are not in log file?
    So, can someone review the settings in the Calc.VET tune? I'm still reviewing but not seeing where I went wrong.
    Also - Is the AFR too lean in the Calc.VET log? Is it safe to be logging for an hour like this? It's leaner than the AutoVE log.
    The AutoVE logging history and vehicle specifics can be found here:
    https://forum.efilive.com/showthread...toVE-questions
    -- Joe
    99 S10 2WD pickup, LS1/A4/MAF/TB from 2000 Z28, LS1B, FAST intake, TPIS cam/springs, shorty headers, 2.5" dual exhaust
    Started w/OS from Silverado modified to run LS1 - IFR/transmission/MAF calibrations from Camaro OS, 13.974@102.85mph (no traction)
    Aug 2013
    Your MAF calibration was way too low and it failed the rationality test.
    I've recalibrated your MAF for you... flash it in and you should be good to go.
    Sep 2009
    So I shouldn't be using the MAF calibration that GM used for that 2000 Camaro MAF? That calibration also functioned before I went OLSD. Not trying to argue, just trying to understand why.
    Aug 2013
    Hey... you asked for a review and I gave you one. Take it or leave it... it's up to you.
    Lifetime Member picnic_george's Avatar
    Jan 2007
    If you already did an autove why not just do an automaf and call it done? You're already halfway there, you should be able to knock out the maf quickly. If your data is way far off from factory with a stock maf, induction setup you might have other issues.
    Sep 2009
    Quote Originally Posted by picnic_george View Post
    AutoVE produced a canyon in the VE map in the 95 kPa column so I thought I'd try CalcVET to see what it produced. VE image is in this post:
    https://forum.efilive.com/showthread...l=1#post175711
    Jan 2007
    The vehicle has a turbo on it? But sticking with the 1 bar map no COS and want to go back to a MAF?
    Sep 2009
    no turbo
    Jan 2007
    I can't look at your tune or log, but it would seem something if off. Do you have a voltage issue? I had a recifier go out on my car and when I would floor it and hit about 3k(engine rpm) it would comepletely shut off the alternator. If something like that is happening it could completely mess up your results. Just something to look for, that VE looks all out of wack at 95kPa.
    I'm also looking thru your files...
  1. Replies: 83
    Last Post: September 5th, 2023, 11:30 AM
  2. Calc.VET: correcting MAF and calculating VE (in single log)
    Last Post: February 20th, 2023, 03:55 AM
  3. Auto VE or Calc VET or Auto Maf?!?!
    By Nver2loud in forum Gen III V8 Specific
    Last Post: October 23rd, 2012, 04:08 AM
  4. Replies: 5
    Last Post: August 31st, 2011, 09:32 AM
  5. Calc.VET, VET Map Average is all 0.0?
    By n8dogg in forum Gen III V8 Specific
    Last Post: July 15th, 2011, 01:20 PM
