Results 1 to 10 of 10
Thread: 2007.5 kodiak OS 12620015
    Nov 2013
    Default 2007.5 kodiak OS 12620015
    I need some help....
    OS 12620015
    This stock file does not show dpf as an option. It is a previous "marta" minibus. Somebody put a straight pipe in place of the DOC and DPF but did not tune it out. It is in limp mode. What do I need to do to tune it out? A friend of mine bought this vehicle and that's all he wants. Please help!!!
    Quote Originally Posted by Rstowe View Post
    OS 12620015
    If you want to send us your ECM, we can fix it for you. Or we can send you another that will meet your needs.
    Custom Tuning Services
    Feb 2012
    I noticed in the last couple of updates they removed the dpf and egr access in some of the CC calibrations. Not sure why though. Pm me if u have questions
    Diesel Forum Support Site Admin
    Nov 2005
    There has been no changes to LBZ/LMM calibration files to remove functionality, although we did 'regenerate' many cal files in our June release.
    If you have noticed anything to the contrary, please PM me the exact calibration numbers and I will investigate.
    Cindy
    Nov 2007
    Cindy I also have a file with same OS that does not have DPF section in the tune. Should I email the tune file to you?
    '04 LB7, AEM Brute Force HD Intake, 4" into 5" single stack, Kennedy Boost valve, EFILive
    Nov 2005
    Back in February we disabled the DSP upgrade option from that specific OS. It appears that something else has happened to that file.
    It will be regenerated for the next public release.
    Cindy
    Nov 2007
    Any idea on a time frame for that? Would it be possible to send you the file and have B2501 and B2502 changed?
    Nov 2005
    I cannot change tune files for customers, sorry.
    I have asked our developers to see if they can pull the cal file from archive for you.
    Public release is scheduled in the next week or so.
    Cindy
    Nov 2005
    Cal file from archive is attached.
    NOTE: DSP is active in this file, please do not use these features.
    Cindy
    Nov 2017
    Cindy
    hello im working on a topkick Kodiak with this os we were hoping to install a dsp5 switch but the upgrade option isn't avalible is it not possible with os 12620015? If not possible with this OS is it possible to switch to another os that is? Thx
  1. 12620015 support for DSP-LMM
    Last Post: April 28th, 2019, 09:59 AM
  2. Error $0322 kodiak 4500
    By Rstowe in forum FlashScan V2
    Last Post: August 7th, 2014, 02:58 PM
  3. Kodiak 06 LLY tuning
    By LS1FREEK in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: November 29th, 2011, 02:28 AM
