Results 1 to 10 of 11
Thread: Spooling the turbo with timing.
    Sep 2005
    Default Spooling the turbo with timing.
    I recently installed a T7675 on my 6.0 litre and am trying to tune for a good spool. It looks like timing in the 30 degree range helps spool the turbo faster. Can someone look at my tune and make some recommendations to perhaps the timing or Boosted timing table.
    Thanks!
    2002 GMC Sierra ECSB
    Turbonetics T7675 6lbs boost, 42lb injectors, Single 4 inch exhaust with Hi-Flow Cats, 6.0 swap, Comp Cam LS9 Cam, EFIlive Tune, E-fans, Snow Performance Meth Kit, soon to add KB Boost a Pump,
    Lifetime Member johnv's Avatar
    Jan 2005
    I hope that isn't your current tune ?
    Wide open throttle timing is pretty high for a std bottom end engine, on pump gas, with boost.
    also you have no power enrichment, commanding 14.63 afr in PE (not safe on a boosted engine)
    Back yard boost
    347+ T76 = 770 rwhp 10.96 @ 135 mph
    I would half that spark map for a start and go from there.
    Sep 2005
    Yeah it is my current tune, however previously used for a blower and it is speed density. I usually run 94 octane and have not had any problems with knock. I will try lowering the WOT timing - It is around 18, how much lower should I go.
    Sep 2005
    I find from observation that the turbo seems to spool very well at 25-30 degrees of timing until I hit boost. Anyone able to post their timing tables?
    Jan 2005
    Aug 10 2014 Turbo_0001.tun
    Have modified you tune file with my timing tables, check history to see what i've done.
    Back yard boost
    Sep 2005
    Hi John, Thanks a lot, appreciate your help very much. I'm going to try it and report back. I was also wondering if I could have a look at your VE tables since I just changed over to a turbo and need a starting point for tuning. Thanks again
    Jan 2005
    Aug 10 2014 Turbo_0002.tun
    Here you go.
    Note - I run 60 lb injectors, non boost referenced fuel regulator, and also have a larger camshaft than you run, so no too sure if my VE table will a close match for your setup.
    Back yard boost
    Sep 2005
    Hi John Thanks again, at least it is a starting point. I have to get emissions first then I'll try this as a starting point for tuning.
    Best Regards
    Sep 2005
    Hi John, the tables were good as starting point - eventually I have to add a 20% factor to ensure I didn't go lean in the Boosted. The timing table worked out well - Thanks again.
    PS is this your high horsepower tune?
  1. Adjusting Pilot Timing when Base Timing is changed?
    By koolky in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: March 20th, 2014, 02:47 PM
  2. More Timing or Less Timing? That is the question
    By n8dogg in forum Gen III V8 Specific
    Last Post: July 30th, 2010, 11:33 PM
  3. Turbo car - pulling more timing then commanded. Anyone seen this before?
    By LS1Nova in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: July 21st, 2010, 10:11 AM
  4. Billet LT1 Timing Cover - Clears Double Row Timing Chain
    Last Post: November 17th, 2009, 01:15 AM
  5. Closing turbo vanes for turbo braking?
    By Haulinbass02 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: May 14th, 2009, 12:12 PM
