So, I was finally able to get the idle hammered out and the truck will go into gear and not die.
The next issue I am having is that whenever I rev the RPMs to about 2K or higher and then when it drops back down, it will drop too low and then stall. This also happens when I am going around corners and the RPMs drop.
The second issue is that when I let off the throttle and the RPMs drop, I am getting knock. So, basically on deceleration. It is shown in the log on frame 702.
My initial thoughts are the engine compensation needs to be increased, but as you can see in the tune, I have increased this way above any values I see in other tunes for similar mods.
Any ideas?
Log_0002.efi
Sleeperado v.01(8-11-2014).ctz
