Results 1 to 10 of 12
Thread: Transmission Manual Mode
    Mar 2012
    Default Transmission Manual Mode
    Does anyone have an explanation of the Transmission Manual Mode operation? I see the Performance option and the table adjustment that would go along with it. I see the wiring for it and what pins in the ECM to use. Nothing on the operation though.
    Mar 2012
    Anyone have any input?
    What TCM/OS...?
    What year/model/vehicle...?
    Mar 2012
    Gen 3 so LS1B. Any year, 4l60 or 80.
    I'm not sure what you mean by "Transmission Manual Mode"...
    the 4L60E/4L80E manual modes limit the range of gears (e.g. Manual 2nd gives only 2nd gear in 4L60E and 1st and 2nd gears in 4L80E)...
    i.e. the PCM still shifts automatically within the range of gears in the manual mode selected (4L60E range is 2nd only, 4L80E range is 1st and 2nd).
    If you're trying to edit the shift curves for Manual 2nd (for example), the post your tune file; which transmission do you have...?
    ( moved thread to 4speed transmission section )
    Mar 2012
    D0409, shift pattern select, is where the option is. I understand the performance option.
    Ok, I'll take a closer look at applications that use D0409.
    Mar 2012
    Cool, thanks!! I have always been lost with that one and never thought about it when I had a rig in my hands to experiment.
    Mar 2012
    Get a chance to look?
  1. Manual transmission temp PID
    By alwaysinboost in forum General
    Last Post: May 5th, 2013, 03:39 PM
  2. How to apply patch for manual transmission
    By Age08 in forum Gen III V8 Specific
    Last Post: March 6th, 2013, 03:19 PM
  3. vss sensor function with a manual transmission.
    By monzaaddict in forum Conversions / Aftermarket Parts
    Last Post: October 27th, 2011, 01:59 AM
  4. OS 11352409 for Manual Transmission Trucks
    By DoghouseDiesel in forum Cummins 5.9L
    Last Post: October 6th, 2011, 04:23 AM
  5. Who can tune a Camaro V8 manual transmission for me ?
    By horst in forum E37, E38 & E67 PFI ECM's
    Last Post: September 13th, 2010, 03:31 PM
